4.2 increased power outputs
R23
Post by R23 » Mon Aug 23, 2010 8:30 pm
Probably been asked a thousand times before but what are the fundamental differences in the models such as the RS4 and the S5 that have the higher power output than the S4? Anything that is interchangable such as improved manifolds or cams?
RE: 4.2 increased power outputs
Post by HYFR » Mon Aug 23, 2010 8:53 pm
S5 doesnt have more HP
well, maybe 6ps
darlo968
Post by darlo968 » Mon Aug 23, 2010 10:12 pm
S5 is the same unit but with Direct Fuel Injection, hence only slight increase in hp. RS4 unit has DFI and a load of other changes that I am not capable of listing, but it is irrelevant - withouth DFI you can't make an S4 engine into and RS4 or S5 engine. The thing I have read about the RS4 unit is that although hp is up considerably, torque increases are not quite as impressive.
R23
Post by R23 » Fri Aug 27, 2010 12:49 am
Fair enough - I had been under the mis-impression that the RS4 was turbo like RS6, but must have been confusing that with the original 2.7 version. Still, a remap and exhaust should make this as fast as you ever need if it is not already!!
Does anybody bother to get into the realms of matching the head and inlet /exhaust manifolds up at a machine shop, flowing the manifolds or any other geekey tricks from the old-school?
xyber
Post by xyber » Fri Aug 27, 2010 1:02 am
I've got a port matched and honed inlet. Adds lots of torque low down
darlo968
Post by darlo968 » Wed Sep 01, 2010 5:31 pm
JHM in the US do exchange inlet manifolds that have basically been flowed, as far as I understand. As per xyber, reports of increased low end torque abound.
xyber
Post by xyber » Wed Sep 01, 2010 6:05 pm
darlo968
Post by darlo968 » Tue Sep 07, 2010 9:15 pm
Sorry, I should have read your signature - the JHM stuff is clearly what you have!
