Warranty renewal time again
Wow the years have gone quick!!
Audi letter arrived to say my warranty is due to expire soon £1700ish for the year
I have had about £5k+ done this year under warranty already
Is anyone having joy with any other company
Warranty wise are Quoting £1200ish for a fairly good cover
warrantydirect aren't quoting...seen this in other threads
AA waiting for a price
I have delt with warranty wise at work a few times and they can be hard work, waiting for engineer to come out and them saying NO to certain items, not covering an Oil leak unless the engine has to come out?
This has been on Porsche not on these beasts, so I was wondering if anyone has this policy and had the usaul things replaced with them, 9 out 0f 10 times is how you word it too them aswell
03 RS6 Saloon Daytona Grey | Milltek | RS6+ Wheels | RS6 Mats | Tesco Club Card Points
RE: Warranty renewal time again
£1700ish sounds very cheap for audi cover. is this the mondial cover, or a dealer specific aftermarket company ?
c5 RS6 plus in silver
You can't put mondial cover on a car beyond its 5th birthday. This won't be the official Audi warranty - is it through a dealer group?
kaisersolsay
Warranty direct quoted me £750 for a years cover
Re: RE: Warranty renewal time again
you can this will be my 3rd year you can cover it upto 9 yearsRupert wrote:You can't put mondial cover on a car beyond its 5th birthday. This won't be the official Audi warranty - is it through a dealer group?
125k it is not full cover but named component only
Inc the roadside assis
£1700 just seems alot when you can cover a Porsche for 995 - 1290 and this Inc £211 check and it is bumper to bumper
Coxall8395
RE: Re: RE: Warranty renewal time again
I have always used Warrantywise and they have been excellent for the last two years on my BMW M3. Mind you I did include the option of wear and tear cover and this is the biggest get out clause there is on warranties.
That is odd. My dealer offered named cover mondial for 2500+. I phoned Audi customer care to be told the same thing. All component at £1240 can be put on up to 5th birthday, then named at £2500+ after that.marmite wrote:you can this will be my 3rd year you can cover it upto 9 yearsRupert wrote:You can't put mondial cover on a car beyond its 5th birthday. This won't be the official Audi warranty - is it through a dealer group?
Can you check it please - my warranty ran out last week and I would have gone for it at that. Both dealer and Audi CS are adamant, I think the amount was £2570. For one year. Renewal.
1...im you 100% can put Audi Mondial warranty on a car on its 6 bday and beyond
2...£1,700 sounds cheap, word on the street is that price went up to £2.4k
Re: RE: Re: RE: Warranty renewal time again
Yes, that is what I understand too, my first post was wrongly worded!aka_dk wrote:1...im you 100% can put Audi Mondial warranty on a car on its 6 bday and beyond
All component up to 5th birthday to give cover up to 6th, then named component after that.
£2500 does not seem good value for named. £1700 would be ok-ish.
Warranty for £431
Just had a quote for £431 for the RS6 this is there terms seems all drc and turbos plus trasmission is covered what do you think is it ok or not? for that price it might be worth a try
Bobby
Direct Debit Payments
Under the terms and conditions for Direct Debit Payments,
Used Vehicle Warranty will take an initial payment outlined
to you when purchasing the policy and subsequent monthly
payments, also outlined to you when purchasing the policy. In
the event of a claim occurring within six months of the policy
being taken out the claim payment will be reduced by the
amount of any outstanding payments up to the sixth month
period. Premiums are collected over a 6 month period.
In the event that a Direct Debit payment fails, the customer
will be contacted to resolve the situation. However, should a
resolution not be possible, then the Policy will cease 1 month
after the Direct Debit failure.
Parts Covered
Engine
Rocker assembly, inlet and exhaust valves, valve guides and
springs (excluding burnt valves and decokes), cylinder head
(excluding cracks and overheating damage), stretch head bolts,
push rods, camshaft and cam followers, timing gears, chains
and tensioner, oil pump, pistons and rings, cylinder bores,
gudgeon pins, con rods and bearings, crankshaft and bearings,
flywheel and ring gear, distributor drive.
Timing Belts
Providing there is proof that the manufacturer’s replacement
recommendations have been complied with and they are free
from oil contamination.
Manual gearbox
Gears, shafts, synchromesh hubs, selectors, bushes, bearings,
speedometer drive, overdrive units (when fitted), solenoid,
transfer box
Automatic gearbox
Gears, oil pump, shafts, bushes, clutch, brake bands, bearings,
governors, servos, torque convertor, drive plate, valve block,
governor, modulator valve, speedometer drive.
Turbo
The complete unit including wastegate. (If the turbo is fitted as
part of the manufacturer’s original specifications)
Drive System (front / rear)
Crown wheel and pinion, half shafts, bearings, planet gears,
bevel gears, rear external drive shafts, constant velocity joints,
4 wheel drive units.
Brakes
Master Cylinder, servo, brake pumps, brake limiter valve, ABS
computer/pumps.
Steering
Rack and pinion, steering box, idler box, power steering, rack/
ram and pump, pressure pipes, reservoir, steering column.
Cooling System
Water Pump, head gasket, thermostat, heater matrix, electric
fan motor, viscous fan coupling, radiator, air conditioning pump.
Propshaft
Propshaft, universal joints and bearings.
Fuel System - petrol/diesel
Mechanical/electrical fuel pump, air flow meter, E.G.R. valve,
idle control valve
Front/rear suspension
Coil springs, upper and lower wishbones, ball joints, swivel
joints, McPherson struts, suspension arms, antiroll bar, self
levelling units and reservoir pump and regulator valves,
displacer, hydro-pneumatic system (excluding bushes).
Wheel bearings
Front and rear wheel bearings.
Clutch
Master cylinder, slave cylinder and clutch cable.
Electrics
Starter/solenoid, alternator, coil, distributor, E.C.U. (engine
only), front and rear window/headlamp wiper motors, heater fan
motor, indicator relay, electric window motor, sun roof motor,
centralised locking solenoids, horn, cruise control actuator and
control unit only.
Casings
In the event of a covered item causing damage to a casing then
the casing will form part of the maximum claim liability.
Excluded from cover all parts not listed above.
Liabilities & Exclusions
Liabilities
The Insurer will be liable for the cost of parts, labour and value
added tax (where this tax is not reclaimed), to the limits as
stated on the Policy Schedule providing that all requirements
have been met, and the failure falls within the scope of this
policy.
This policy provides cover for Mechanical Breakdown which is
defined as:
1. The actual breakage of a mechanical part covered
2. The complete failure of an electrical part covered
Exclusions
1. The following are not covered by this policy:
a) Modified vehicles unless approved by the manufacturer
b) Vehicles used for hire and reward
c) Vehicles used for racing or competition.
d) Commercial vehicles of 3,500kgs and above.
2. This policy does not cover death, bodily injury, accidental
damage, consequential loss, or any other damage
howsoever caused.
3. This policy does not cover wear, inherent faults, faulty
workmanship, cracked blocks, cracked cylinder heads, burnt
valves, oil and fluid leaks, accidental damage to radiator.
4. Failure to observe the following will invalidate your claim:
a) Frost protection
b) Correct claims procedure
c) Servicing
5. This policy does not cover damage caused by negligence,
i.e. insufficient oil or water, overheating, or failure to ensure that
minimum damage is incurred by taking preventative measures.
6. Mechanical Breakdown or damage arising from the use of
a grade of fuel not recommended by the manufacturers of the
Insured Vehicle.
7. Exhaust emission MOT failures are not covered by this policy
as they are not a mechanical breakdown.
Terms and Conditions
1. No part of this policy may be altered without the written
consent of WMS.
2. WMS reserve the right to appoint the repairer of the
vehicle, the supplier of the parts, and where available service
replacement parts will be used.
Bobby
Parts Covered
Engine
Timing Belts
Manual gearbox
transfer box
Automatic gearbox
Turbo
Brakes
computer/pumps.
Steering
Cooling System
Propshaft
idle control valve
Wheel bearings
Clutch
Electrics
control unit only.
Casings
Liabilities
policy.
defined as:
Exclusions
howsoever caused.
a) Frost protection
c) Servicing
Insured Vehicle.
consent of WMS.
RS6 Saloon 04- Non Res Milltek- Forge dump valves- Led Rear Lights- Ally steering paddles- 20" Rotors- RNS-E- I.G Air Fiters,
RE: Warranty for £431
its a double edged sword....i wouldn't pay £2.5k for an Audi Warranty, but wouldn't have the stomach to run an RS 6 without one...unless it was a 2nd car
Re: Warranty for £431
Who is that £431 covered with? V cheeeep!rob8457 wrote:Just had a quote for £431 for the RS6 this is there terms seems all drc and turbos plus trasmission is covered what do you think is it ok or not? for that price it might be worth a try
RE: Re: Warranty for £431
i cannot say yet as i am going to ring them monday to find out some more details on the cover i do not think they know about the drc issues the last time there was a cheap warranty cover advertised on this bourd everyone rang them and then they refused to cover the rs6, but at this moment they are listing it for there cover to the maximum cost of the car, i will find more out and if i decide to get it then i will post there contact details on hear.
Bobby
Bobby
