Changing clutch without flywheel?
RS_Y4Z
Post by RS_Y4Z » Wed Jun 16, 2010 8:16 pm
Guys my mates done his pressure plate in but his clutch is not slipping, car has only 18K bump start it in gear and it drives fine, no slip no issues. Is it ok to just change clutch and release bearing and not touch flywheel?
ArthurPE
RE: Changing clutch without flywheel?
Post by ArthurPE » Wed Jun 16, 2010 8:26 pm
if it drives fine what makes you think the clutch is shot?
if it's not slipping?
bump start? maybe it's the starter or flywheel teeth?
if the flywheel is not warped by heat/scored by rivets it can be reused...
RS_Y4Z
Re: RE: Changing clutch without flywheel?
Post by RS_Y4Z » Wed Jun 16, 2010 9:06 pm
ArthurPE wrote:if it drives fine what makes you think the clutch is shot?
It wont go into gear when started or driving. And it takes 60men to get it out of gear!!
RS_Y4Z
RE: Re: RE: Changing clutch without flywheel?
Post by RS_Y4Z » Wed Jun 16, 2010 10:34 pm
Guys where can he get an OEM clutch other than audi main dealers???
sonny
Post by sonny » Thu Jun 17, 2010 5:38 pm
Sound like your servo has gone, prob due to a split hydro pipe. Will it only go in gear if the engine is switched off?
ArthurPE
Re: RE: Re: RE: Changing clutch without flywheel?
Post by ArthurPE » Thu Jun 17, 2010 8:13 pm
sonny wrote:Sound like your servo has gone, prob due to a split hydro pipe. Will it only go in gear if the engine is switched off?
my thoughts also
it is a hydraulic issue, not the clutch per se
perhaps the hose, perhaps the slave cylinder...
check those out first
any loss of fluid?
sonny
RE: Re: RE: Re: RE: Changing clutch without flywheel?
Post by sonny » Thu Jun 17, 2010 8:20 pm
TBH it sounds like the symptoms I had when my clutch went. (due to the weak hose).
Sims
Re: RE: Re: RE: Re: RE: Changing clutch without flywheel?
Post by Sims » Thu Jun 17, 2010 9:50 pm
sonny wrote:TBH it sounds like the symptoms I had when my clutch went. (due to the weak hose).
There is a TPi (Tech Product info) on this and I had a new clutch pipe fitted - could be between slave and master cylinder.
RS_Y4Z
Post by RS_Y4Z » Thu Jun 17, 2010 10:41 pm
Yes this is correct.
RS_Y4Z
my thoughts also
any loss of fluid?
Is a split hydro pipe covered under warranty.
ArthurPE
Post by ArthurPE » Thu Jun 17, 2010 11:23 pm
RS_Y4Z wrote:
my thoughts also
any loss of fluid?
if the car has a valid warranty it should be covered...
the clutch is another matter, they may argue 'wear & tear'
Users browsing this forum: Google Adsense [Bot] and 226 guests
