2NG Gear traction control cutting in
nuthintoprove
Hi Guys
Been keeping tabs on this board a while but this is my first post i think.
Having had a B7 RS which i never fell in love with I am now in to a B5 which was always my dream car, better looking, classic audi turbo,rarer and so should depreciate less from here in etc etc ............... and i have just taken delivery of a 50000mile example.
However 2 driver issues........1 when you spank her through the gears, more often than not, the traction control cuts in arround 3000-4000 revs, only in second gear, and shuts down the power down for far too long....................also squeeking and shuddering brakes.
I think the previous owner had'nt driver the car more than 1000 miles in the past year, and the rear discs were very rusty.
Is this the way these B5s behave with regards to the traction control.....never had an issue with a B7
Cheers for your thoughts
jimbo1234567
- 5th Gear
RE: 2NG Gear traction control cutting in
traction control cuts the ignition on these cars.
665 bhp + 586 lbft...
That's why I turn it off......
Re: 2NG Gear traction control cutting in
Congrats on the new addition! Two recommendations:nuthintoprove wrote:However 2 driver issues........1 when you spank her through the gears, more often than not, the traction control cuts in arround 3000-4000 revs, only in second gear, and shuts down the power down for far too long....................also squeeking and shuddering brakes.
Make sure that you have the blinking traction control light coming on, otherwise there is something else that causes the power to fall off. I would not recommend shutting off the traction control on public roads before you have a better feel for the car. I have driven a B7 RS4 before and I saw traction control coming in much more gentler than in the B5 at the limit.
With respect to the brakes, I would recommend bedding them in. You should be able to clear the rust around the outer portion of the rear disk and the shudder should go away. Provided they are OEM pads, you should have no squeeking. The rust will re-appear during extended city riving.
Enjoy!
'00 S4 (sold)
'01 RS4 (sold)
'93 964RSA
'94 964 Turbo
'08 E63 AMG
'10 Cayenne GTS
'01 RS4 (sold)
'93 964RSA
'94 964 Turbo
'08 E63 AMG
'10 Cayenne GTS
Mine has just started doing this, but in 3rd gear under heavy acceleration. Its the traction control cutting the ignition. Caused by a failure in one of the four Lambda sensors. Switching off ESP stops this which is a temporary fix. I had a full road test with the laptop plugged in to identify the fault.
Check your tyres , If they are not a matched set you could get some wheel spin .. That would bring on the TC light.
Unit 20
0151 3366888
0151 3366888
Try it when it's wet and you run toyo 888's ...davey wrote:me to , ever since I heard Jimbo suggest itdace wrote:I never drive with traction control on. Turn it off the minute yoo fire up the beast....
Unit 20
0151 3366888
0151 3366888
