"ECON" button stuck on and recall work....
bye bye
Post by bye bye » Tue Apr 13, 2010 8:47 am
Hi,
I booked my car in to dealer as my "econ" button is stuck on. When the engine isn't running but ignition on it goes off but as soon as I start the car it comes on??? With warm weather it's become a prominent issue for me.
Before they try to charge me for an aircon "recharge" has anyone else had such an issue. I know my dealer and I'm sure they will claim it is not coverecd by the "Audi All Component Warranty" I've read the paper work and it doesn't exclude aircon but the last time my car was in for DRC leak they said they were doubtful it would be covered by warranty!!
Also, when I booked it in I was told there was a recall job to replace an "oil pipe". I have a December 2006 car.
Mark
RS4KILLA
RE: "ECON" button stuck on and recall work....
Post by RS4KILLA » Tue Apr 13, 2010 9:49 am
common problem with the b6 a4's some valve problem was a few years ago had a similiar issue
B5 S4 KO'4 black saloon sunroof......
B5 RS4 Goodwood Green,sunroof, nav tv, short shifter,
B5 S4 Nogaro saloon
B5 S4 Black saloon,
B5 RS4 Misano red,
B5 RS4 noggy blue,
B7 RS4 Sprint Blue.
B5 RS4 avus silver
RS4KILLA
Post by RS4KILLA » Tue Apr 13, 2010 9:51 am
00819 - High Pressure Sensor (G65)
00819 - High Pressure Sensor (G65): Signal too Low
Possible Symptoms
* Climate Control stuck in ECON Mode
Possible Causes
* Insufficient Refrigerant Pressure
* Wiring/Connectors from/to High Pressure Sensor (G65) faulty
* High Pressure Sensor (G65) faulty
Possible Solutions
* Check Refrigerant Pressure
o Check Measuring Value Blocks (MVB)
* Check Wiring/Connectors from/to High Pressure Sensor (G65)
* Check High Pressure Sensor (G65)
B5 S4 Nogaro saloon
B5 S4 Black saloon,
B5 RS4 Misano red,
B5 RS4 noggy blue,
B7 RS4 Sprint Blue.
B5 RS4 avus silver
RS4KILLA
was about £40 for the sensor
B5 S4 Nogaro saloon
B5 S4 Black saloon,
B5 RS4 Misano red,
B5 RS4 noggy blue,
B7 RS4 Sprint Blue.
B5 RS4 avus silver
Angelo_Amato
Post by Angelo_Amato » Tue Apr 13, 2010 12:17 pm
OIL PIPE - recall is to add a couple of clips, don't think it was pipe replacement, but be good to ask as some do corrode by the sounds of it on here.
Users browsing this forum: Google [Bot] and 364 guests
