Rs4 Downpipes
- rothschild
Rs4 Downpipes
About a month ago I got my Tubi exhaust installed. Had (and still having) fun but it seems quiet now that I've got used to it. Thinking about buying a set of downpipes for it. Mainly interested in sound gains. Has anyone here tried that? Any problems I might encounter? (With ecu perhaps?) Does it require a remap with downpipes?
- rothschild
Well actually the downpipes do make it a little bit louder (more raspier) due to increased airflow I think. Here is a clip on YT: http://www.youtube.com/watch?v=PUjK97L7z3c
I wouldn't change the center pipe though. Afraid it might be too loud or start to drone or whatever.
Does your Tubi come with resonators? Personally for more volume I would just remove those and instal and x or h pipe, removing or replacing cats really needs a remap to compenaste for the loss in back pressure in the system and take advantage of the freer flowing exhaust which a standard map could only partially do.
If your Tubi is valved then you can use this function to eliminate drone around town if it happens, depends on the resonance frequency of the Tubi and pipe diameter.
Your Tubi seems quiet!? I've never found that and it never drones. There is a Tubi centre pipe I believe available too.
RS3 Saloon, Merlin Purple, incoming.....
S3 Sportback Black Edition, Panther Black, BBS CHs
Previous:
RS6 C7 Riviera Blue, Carbon Pack, Sports exhaust, BC Forged HS04
C63 AMG Coupe, Fire Opal Red, Performance Pack, HRE P44SC's
RS4 B7 Saloon, Avus Silver, HRE P40s, Tubi exhaust
Volvo S60 R Black Saphire, Evolve Suspension + aerodynamics, BMC
Volvo S40 T4 Standard
Previous:
Re: Rs4 Downpipes
rothschild wrote:About a month ago I got my Tubi exhaust installed. Had (and still having) fun but it seems quiet now that I've got used to it. Thinking about buying a set of downpipes for it. Mainly interested in sound gains. Has anyone here tried that? Any problems I might encounter? (With ecu perhaps?) Does it require a remap with downpipes?
Hi there,
I did have a total straight through system and it was insane!!
if you dump the cats altogether you will see at least 10 or 14bhp gain but you will need a custom remap in order to get the benefit. if you just fit them you will lose power not gain it. You will gain volume but the car will have a rasp to it which you may or may not like.
good luck, if you need any more help drop me a PM
cheers
Jim
Current car..... hmmmmm????
RS4 B7 Gone
RS6 C5 Gone
M3 E46 smg Gone
S3 Gone
RS4 B7 Gone
RS6 C5 Gone
M3 E46 smg Gone
S3 Gone
- rothschild
Thanks for the replies, guys! My Tubi is just a catback. And no it is not quiet but it's quieter than I thought it would be. Concerning the Tubi centre pipe - they found out that it caused resonance and vibration on the back seats and stopped all production of it.
I might try getting myself an aftermarket resonator and see if it helps. Hopefully it'll be a bit louder and still won't drone. What do you think?
matthew.lewis2
I currently have a full decat, straight centre section and std rear boxes. with just the decat and std cat back i found it still too quiet (but not raspy at all). So...i removed the centre resonator and it is now raspy.
To give me the volume and sound quality I am seeking I am looking at either a resonated + valved Milltek or Capristo system. Capristo ONLY if they can do me a deal because it is prohibitively expensive.
Tubi is not of interest to me as it is non-valved, and only comprises the rear silencers (i know that both the valves and centre section can be provided), but then we are in Capristo territory, and if I am spending that kind of money i prefer the Capristo tailpipe design.
- rothschild
matthew.lewis2
No, I definitely meant resonated. The decat I have gives added volume, but with unpleasant raspiness when combined with my existing non-resonated centre section.rothschild wrote:Resonated + valved Milltek sounds no louder or more aggressive than stock exhaust. Maybe you meant non-resonated?matthew.lewis2 wrote:
I am looking for a centre resonator to eliminate the rasp.
When you say "Resonated + valved Milltek sounds no louder or more aggressive than stock" is that when the valves are open or closed? Or in both circumstances, the system is similar to stock?
- rothschild
It's very very quiet despite the valves position. I used to have it. Bought Tubi a week later.
What I suggest is a decat with resonators + Tubi catback. Trust me, you won't be disappointed. But that will probably require a ecu remap as most of the people here told me.
As for me, I'm just looking at a Supersprint resonated centre section to take place of the stock resonator. Hope it'll work.
- rothschild
Here's a clip on Youtube of Tubi with downpipes.
http://www.youtube.com/watch?v=zEiYdpHN ... re=related
matthew.lewis2
When I remove my std centre resonator i inspected that, and found it was of "straight through" design, so you may not realise any sound gains by changing to a supersprint resonated section.rothschild wrote:As for me, I'm just looking at a Supersprint resonated centre section to take place of the stock resonator. Hope it'll work.
In your situation, I wouldn't bother with the supersprint, or any other centre resonators, just stick with the std centre section.
- rothschild
Users browsing this forum: Google [Bot], Zyox and 446 guests
