Glad to be back on the forum after a computer glitch...my old username was Bluekermit.....
Need some advice on the rear brake upgrade to GT3 monoblocks. I had the fronts done and its a fantastic improvement and now I want to do the rears. I want to avoid the hassel of the old design and my discs need replacing now so I'm going for the monoblocks... BUT what discs do I need ?
I have 965 Turbo S discs on the front which are drilled and would like to use drilled on the rears also, does anyone know the Porsche part numbers for this disc or which model they come from ?
Appreciate your help.
PAUL
GT3 Monoblock Brake Upgrade for the rear ?
RE: GT3 Monoblock Brake Upgrade for the rear ?
Unfortunately there is no porsche drilled rear disc, the porsche disc is a 928 disc but came in solid form only.
I will be using a 996 rear calipers with a custom bracket
Give compbrake a try they will make you discs to what you need.
Have you been through them? how much would they roughly charge?
I emailed them about getting some front discs made for the rs2 they asked for the discs or dimensions then they could give me a price but it would be cheaper than new oem discs. Send them a email and ask.
