C5 RS6 TPMS
vikingrs6
C5 RS6 TPMS
Post by vikingrs6 » Thu Mar 18, 2010 12:15 pm
Hi
Does anyone know if the TPMS within the settings menu can be switched on/off via VAG-COM?.. The option isn't in the Settings Menu on the dash display but I can get the pressures etc via VAG-COM so the TPMS must be working..
Ta
RS6 C6 - Stock atm but will be getting an MRC Stage 2 shortly
RS6 C5 - H&R'd and MRC'd Happy Days!..
GardinerG
RE: C5 RS6 TPMS
Post by GardinerG » Thu Mar 18, 2010 12:53 pm
Hmmm, might be part of the Instrument Cluster coding, but I'm not sure.
RE: C5 RS6 TPMS
Post by Shoppinit » Sat Mar 20, 2010 10:38 am
In Instruments, there's a value in adaptation channel 61 for the tyre pressure. Maybe it's been turned off? What value have you got in this channel?
vikingrs6
Re: RE: C5 RS6 TPMS
Post by vikingrs6 » Wed Mar 24, 2010 10:11 am
Shoppinit wrote:In Instruments, there's a value in adaptation channel 61 for the tyre pressure. Maybe it's been turned off? What value have you got in this channel?
Thanks, will check it out and post back..
Return to “DTC / VCDS”
