Odd DTC after MAF change. No wiki entry
Post by Shoppinit » Mon Mar 15, 2010 11:14 pm
Changed both MAFs today for genuine Bosch ones. Car runs like crap and is throwing the following codes.
Any ideas? Can't find any info on 17416 DTC.
Code: Select all
Monday,15,March,2010,21:48:26:19387
VCDS Version: Release 908.1
                Address 01: Engine       Labels: 077-907-558-BCY.LBL
Control Module Part Number: 4D1 907 558
  Component and/or Version: 4.2l V8/5VT     G   0002
           Software Coding: 0010752
            Work Shop Code:
4 Faults Found:
17535 - Fuel Trim; Bank 1 (Mult): System too Rich
        P1127 - 002 - Lower Limit Exceeded - Intermittent
17544 - Fuel Trim: Bank 1 (Add): System too Lean
        P1136 - 001 - Upper Limit Exceeded
17546 - Fuel Trim: Bank 2 (Add): System too Lean
        P1138 - 001 - Upper Limit Exceeded
17416 - Mass Air Flow Sensor 1/2: Implausible Signal
        P1008 - 008 - Implausible Signal - Intermittent
Readiness: 0010 1101
jangol
Re: Odd DTC after MAF change. No wiki entry
Post by jangol » Fri Oct 31, 2014 11:19 pm
Did u ever hear anything back.. I'm now getting the 17416 P1008 error code
Post by Shoppinit » Fri Oct 31, 2014 11:27 pm
It was my airbox not seated properly. I took it off and reseated it and all was good.
You need to make sure there's no springiness in the air box towards the back. If there is it isn't on properly.
It's a properly <beep> design.
Post by bam_bam » Fri Oct 31, 2014 11:29 pm
Wow, proper zombie thread on Halloween.
Post by Shoppinit » Fri Oct 31, 2014 11:31 pm
:thumbs:
jangol
Post by jangol » Sat Nov 01, 2014 11:02 pm
All seems to be fine now. There's not much u can do to reseat the airbox... It's the Mafs that need to be seated, unless I missing the point. Anyhow removed airbox off removed Mafs from airbox.. Putt all back together & so far it appears to be fine... Been driving locally & it feels much better... No idea what wasn't seated properly, but hey...
Return to “DTC / VCDS”
