brake rotor dimensions
2.7 V6 30v biturbo - 380 bhp
RS4inGermany
Post by RS4inGermany » Thu Mar 04, 2010 9:46 pm
I am going to upgrade the brakes on my B5 RS4. I am trying to determine the rotor dimension for the front and rear rotors on the B7 RS4.
I have searched through the brake upgrade threads on both the B5 & B7 forums and I'm unable to locate the dimensions. In the B5 sitcky it lists the rotor's OD (front) @ 360 mm and the (rear) @ 312 mm.
Stock B5 RS4 (F) 360x34(?) (R) 312x10(?)
Stock B7 RS4 (F) 362x34(?) (R) 324x10(?)
I am considering either the
B7 setup
AP Racing (F) 365x34mm (R) 343x(?)
Alcon setup (F) 370x32 (R) 310x28mm.
The AP Racing set is the same many already use. Does anyone have problems with the brake bias using the rear setup (4 piston caliper and 343 mm rotor)? The Alcon set has new rotors front and rear. The Alcon set uses new calipers in the front but the stock caliper in the rear. I have not found a thread discussing the Alcon setup. The Stasis web site indicates their kit will fit under the stock wheels (6 piston monoblock caliper and 370 mm rotor).
davs4
RE: brake rotor dimensions
Post by davs4 » Thu Mar 04, 2010 10:19 pm
Std B5 360mmx32mm (Front), 312mmx22mm (Rear)
Std B7 365mmx34mm (Front), 324mmx22mm (Rear)
RS4inGermany
Post by RS4inGermany » Fri Mar 05, 2010 11:19 am
thanks for the size info.
do you have any experience with the Alcon brake setup?
jimbo1234567
Post by jimbo1234567 » Fri Mar 05, 2010 12:49 pm
ap fronts are 365x36 rears are 343x22or24
Blue_Thunder
Post by Blue_Thunder » Fri Mar 05, 2010 1:25 pm
Never realised there was only 5mm difference between B5 and B7 front discs.
jimbo1234567
Post by jimbo1234567 » Fri Mar 05, 2010 9:54 pm
+2mm :beerchug:
