I have full paid ross tech software but cant stretch to the $350 at the moment for the original cable, plus its an emergency driving to Amsterdam Wednesday!
Ta
Any ebay cables let you clear fault codes?
- Top Gear
RE: Any ebay cables let you clear fault codes?
I have a genuine Ross-Tech serial cable without a dongle. If you are sure that it's your software that's licensed (newer cables all have a dongle - hardware which stores the license), this should work fine for you.
Saying that, licensed software should in theory work with the eBay cables to.
- PetrolDave
Some (most) of the eBay cables only work with older versions of VAG-COM either 3.11 or 4.09 see http://www.ross-tech.com/vcds/download/
- Top Gear
Re: RE: Any ebay cables let you clear fault codes?
Don't think any cables other than the genuine Ross-Tech cables with dongles work on anything later than 409.1PetrolDave wrote:Some (most) of the eBay cables only work with older versions of VAG-COM either 3.11 or 4.09 see http://www.ross-tech.com/vcds/download/
- PetrolDave
There are some eBay cables that (briefly!) work with a hacked version of the 6xx version of VAG-COM.Blue_Thunder wrote:Don't think any cables other than the genuine Ross-Tech cables with dongles work on anything later than 409.1
