did a log of a naboughs car today and came up with this
Address 01: Engine Labels: 079-910-560-BNS1.lbl
Part No SW: 8E1 910 560 HW: 8E1 907 560
Component: 4.2L V8/4V FSI ª0090
Revision: 57H13--- Serial number: XXXXXXXXXXXXXX
Coding: 010C0003180F0160
Shop #: WSC 00185 210 88124
3 Faults Found:
001169 - Secondary Air Injection System: Bank 1: Insufficient Flow
P0491 - 002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 1
Mileage: 49554 km
Time Indication: 0
Freeze Frame:
RPM: 1470 /min
Load: 46.3 %
Speed: 20.0 km/h
Temperature: 19.0°C
Temperature: 15.0°C
Absolute Pres.: 990.0 mbar
Voltage: 13.081 V
012555 - Low Pressure Fuel regulation: Fuel Pressure Outside Specification
P310B - 002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 50025 km
Time Indication: 0
Freeze Frame:
RPM: 780 /min
Load: 25.1 %
Speed: 0.0 km/h
Temperature: 29.0°C
Temperature: 11.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 13.716 V
006435 - Please Check DTC Memory of ECU Number 2
P1923 - 008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 1
Mileage: 50052 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 69.0°C
Temperature: 57.0°C
Voltage: 11.938 V
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 8E0-910-517.lbl
Part No SW: 8E0 910 517 G HW: 8E0 614 517 BD
Component: ESP8 quattro H06 0150
Revision: 00000000 Serial number: 00000000000000
Coding: 0004533
Shop #: WSC 06335 000 00000
No fault code found.
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 BM
Component: A4 Klimaautomat 2833
Coding: 00000
Shop #: WSC 00000
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 N
Component: int. Lastmodul ECE 0907
Coding: 11021
Shop #: WSC 65536
Address 11: Engine II Labels: 079-910-560-BNS2.lbl
1 Fault Found:
005137 - Secondary Air Injection System; Bank 2: Insufficient Flow
P1411 - 002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 49554 km
Time Indication: 0
Freeze Frame:
RPM: 1469 /min
Load: 46.6 %
Speed: 20.0 km/h
Temperature: 19.0°C
Temperature: 15.0°C
Voltage: 13.208 V
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 G HW: 8E0 959 655 G
Component: Airbag 9.41 H12 3730
Revision: 91H12373 Serial number: 0036M0G3C2U8
Coding: 0431612
Address 16: Steering wheel Labels: 8E0-953-549-T.lbl
Part No: 8E0 953 549 T
Component: Lenksáulenmodul 0301
Coding: 06022
Shop #: WSC 06335
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 981 R HW: 8E0 920 981 R
Component: KOMBI+WFS 4 H14 0040
Revision: 0040 Serial number: 00000000000000
Coding: 0023411
Shop #: WSC 00185 210 91035
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8E0 035 192 K HW: 8E0 035 192 K
Component: RNS-E HIGH EU H72 0500
Revision: 01S Serial number: AUZBZ7F1181401
Coding: 0309713
Shop #: WSC 02195 785 00200
2 Faults Found:
02261 - Data Medium
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 5
Fault Frequency: 1
Reset counter: 97
Time Indication: 0
Date: 2010.01.29
Time: 08:37:41
Freeze Frame:
Mileage: 655350 km
Count: 2901
Clock: 08:39
00858 - Connection; Radio ZF Output to Antenna Amplifier
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 101
Time Indication: 0
Date: 2009.06.29
Time: 09:32:54
Freeze Frame:
Mileage: 655350 km
Count: 2901
Clock: 10:41
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8E0 951 177
Component: Innenraumueberw. 0804
Coding: 00001
Shop #: WSC 00000
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 CH
Component: Komfortgerát T3B 4135
Coding: 07151
Shop #: WSC 06335
Part No: 8E2959802E
Component: Tõrsteuer.FS BRM 0706
Part No: 8E2959801E
Component: Tõrsteuer.BF BRM 0706
Part No: 8E0959801E
Component: Tõrsteuer.HL BRM 0606
Part No: 8E0959802E
Component: Tõrsteuer.HR BRM 0606
4 Faults Found:
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00962 - Alarm via. Tilt Sensor
35-00 - -
00955 - Key 1
35-10 - - - Intermittent
01559 - Drivers Door
60-10 - Won't Safe - Intermittent
Address 55: Xenon Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 F
Component: Dynamische LWR H02 0010
Revision: 00000001 Serial number:
Coding: 0000005
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0309713
2 Faults Found:
02261 - Data Medium
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 97
Time Indication: 0
Date: 2010.01.29
Time: 08:37:41
Freeze Frame:
Mileage: 655350 km
Count: 2901
Clock: 08:39
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 101
Time Indication: 0
Date: 2009.06.29
Time: 09:32:54
Freeze Frame:
Mileage: 655350 km
Count: 2901
Clock: 10:41
Address 65: Tire Pressure Labels: 8E0-907-273.lbl
Part No SW: 8E0 907 273 A HW: 8E0 907 273 A
Component: Reifendruck 3 H04 0130
Coding: 0022523
Shop #: WSC 02197 785 00200
Address 76: Park Assist Labels: 8E0-919-283-8EC.lbl
Part No SW: 8E0 919 283 E HW: 8E0 919 283 E
Component: Parkhilfe 8-Kan H06 0010
Revision: 00H06000 Serial number: 00067802120624
Coding: 0000114
End ---------------------------------------------------------------------
any thing to woory about?
RE: any thing to woory about?
I have had this one before and cleared it. Hasn't come back yet and I'm told it's part of the emissions system for the US market. which can be removed or cleaned out The replacement parts are not to expensive. I'm sure you'll get more answers about the other faults.
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 49554 km
Time Indication: 0
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 49554 km
Time Indication: 0
R18 GTX Estate > Saphire 2.0i Ghia > R19 16v > Vectra V6 SRi > M3 > RS6 Avant
Brooner, check out the label file for the engine module and you will see up at block 77 you can run tests on the SAIS in basic settings.
I did this on mine when I was getting insufficient flow on both banks.
If you are getting low flow on both banks then it can be the following;
The solenoid valve that creates the vacuum to open the SAIS inlet valves is dead
The vac pipe from the solenoid valve to the SAIS inlet valves has failed
The secondary air pump is dead or the output pipe has come off (can you hear it work when cold?)
Using the basic settings block 77 with engine running , the secondary air pump is run and the inlet valves are opened by the solenoild valve and flow is measured, if in spec it says 'SYSTEM OK or if not, 'SYSTEM NOT OK'
While it's doing the test you can pop the vac pipes of the SAIS inlet valves and see if you can feel vacuum there, just try the nearside one first as it's easier than the offside one, if one work, chances are the other will. If there is vacuum then the solenoid valve is fine.
You can run the pump and solenoid valve via output tests but without engine running it's not that useful.
thanks Neckarsulm bit to technical for me but will see if the nabour is up to that
2018 B9 RS4 Navarra Blue
2013 B8 RS4 Sepang Blue
2007 B7 RS4 Avant Sprint Blue
2001 B5 RS4 Nogaro Blue
1993 B4 S2 Avant laser Red
Re: RE: any thing to woory about?
It's not hard honest!Brooner wrote:thanks Neckarsulm bit to technical for me but will see if the nabour is up to that
Label file is the filename visible when you go into measuring blocks at top of screen - click it and it will open in notepad where you can scroll down all the fields that can be read for that ECU
You'll see 77 is for SAIS diagnostics.
Go to 77 in measuring blocks the switch to basic settings and with engine running the air pump will fire up, VAG COM will measure the flow and say 'OK' or 'NOT'
I did mine from cold as that's when SAIS works in normal situations.
RE: Re: RE: any thing to woory about?
k will try it out thanks (i'm a bit of a mechanical <beep>)
Have a look at my label file posting in this forum, scroll down to 77
So am I, the introduction of computers to cars was a good thing for me as I never really got on with spanners.k will try it out thanks (i'm a bit of a mechanical <beep>)
