Rear Inner Parking Sensor
Maximo
Post by Maximo » Wed Jan 27, 2010 11:03 am
Is there a way of replaceing the sensor with out taking the bumper off? I've had a quick look and can get my hand on the sensor but not sure how it disconnects from either the bumper or the cable. There seems to be enough room to get movement but not that much.
If it makes any difference we're talking about an Avant.
RE: Rear Inner Parking Sensor
Post by Shoppinit » Wed Jan 27, 2010 12:08 pm
I posted recently about how the sensors are clipped to the bumper.
Shoppinit wrote:They are held in by plastic spring tabs on each side. YOu have to spread the tabs slightly then press the sensor in from the outside. You can then disconnect it.
YOu're supposed to remove the "rear bumper cover" whatever that is. If you can get reach your hand to the sensors, you might be able to remove it without removing the bumper; Maybe someone who has done it can give better advice.
Maximo
Post by Maximo » Wed Jan 27, 2010 5:19 pm
Thanks for that info. I shall have a go over the weekend and see how I get on, hopefully all will be good.
R18 GTX Estate > Saphire 2.0i Ghia > R19 16v > Vectra V6 SRi > M3 > RS6 Avant
Stupidog
Post by Stupidog » Sat Jan 30, 2010 10:25 pm
Did you get it out?
I tried cleaning mine from the outside with some sucess but it aint perfect
Maximo
Post by Maximo » Sun Jan 31, 2010 12:00 pm
Not had a chance so far, still waiting on the replacement sensor arriving. I may have a go at cleaning it in the mean time and see if that helps.
Stupidog
Post by Stupidog » Sun Jan 31, 2010 10:00 pm
I tried cleaning it in situ with a dremmel, it kind of worked but make sure you mask the bumper well. I touched the edge and so had to paint that too which shows as it's new paint and no gap like there is on the sensor to hide the work.
I can see it bugging me and a front back bumper paint having to be done :roll:
Maximo
Post by Maximo » Wed Feb 10, 2010 11:42 pm
Had a go over the weekend replacing the sensor, there doesn't seem to be enough room with the bumper on the car. Can any one tell me how I go about removing the rear bumper from an Avant?
Post by Shoppinit » Wed Feb 10, 2010 11:52 pm
http://www.rs6.com/forum/showthread.php?t=18725
Sorry. Just read your post properly.
There was a post about it recently. Hold on.
MoRS6+
Post by MoRS6+ » Thu Feb 11, 2010 12:33 am
I'm in exactly the same boat; same sensor.
Watching eagerly...
Post by Shoppinit » Thu Feb 11, 2010 7:45 am
Try this:
bumper.pdf
bumper removal
(177.56 KiB) Downloaded 336 times
Maximo
Post by Maximo » Thu Feb 11, 2010 11:20 pm
Going away for the half term break so will have a go in a couple of weeks and report back. Looks like there is a lot og bits to remove along the way.
Users browsing this forum: Shoppinit, srichards, steve2003rs6 and 124 guests
