Using RNS-D GPS antenna with a splitter
Post by Shoppinit » Thu Jan 21, 2010 3:15 pm
Being fed up with having no GPS reception inside the car, I have bought a GPS repeater that has an external antenna and retransmits the GPS signal inside the car.
http://www.gpszone.ca/accessories/antennas/wide-gps.php
Instead of using the supplied (active) antenna, I'd quite like to use the OEM one going to my RNS-D via a splitter.
Could this work? Even if my repeater is trying to power an antenna? Is the RNS-D trying to power the OEM antenna on the roof?
CheeRS :)
P.S. Also, where can I get 12v supply from inside the glovebox that'll go off with the ignition? Thanks!
craigyb
RE: Using RNS-D GPS antenna with a splitter
Post by craigyb » Thu Jan 21, 2010 6:55 pm
I used a GPS splitter to supply GPS Information to an origin B2 speed camera detector. Seemed to work great, I think the splitter blocks the power from the second feeding device. So the RNS-E in my case powered the GPS roof antenna.
Return to “Electrical”
Users browsing this forum: No registered users and 6 guests
