My EMS light came on, with no other warnings. But when I tried to check DTCs with VAG-COM, it wouldn't connect (com port OK, but host not found).
Anyone else had this problem before or have any ideas?
I guess I could try disconnecting the ECU, just to see if I can then connect to other modules with VAG-COM.
Alternatively I could try resetting the ECU. Presumably that can only be done by disconnecting the battery?
Engine Management System light problem
2001 Silver S4 Avant
- PetrolDave
Re: Engine Management System light problem
Just checking that you had the ignition turned on? That's the most common reason for that error message.Dippy wrote:(com port OK, but host not found).
Can you connect to any other controllers, e.g. address 1 (engine ECU),
RE: Re: Engine Management System light problem
Thanks Dave. I think it was a laptop problem. I updated my VCDS and USB driver and tried again with complete success. It turns out the that fault is an old fault I inherited when my Miltek exhaust was fitted (I believe it runs a bit too cooler than standard so a temperature is sometimes below threshold). The only mystery is why in the past several years it is the first time (as far as I know) that it has invoked my EMS light. Normally I just notice it when checking DTCs and clear it.
