I keep getting these warning's on the wifes A4 DTM (2.0tfsi). It has an uprated fuel pump and sports air filter element with a Revo Map. Any ideas?
The fuel consumption is excellent, 40-45mpg on a spirited run. I am thinking the map is too lean therefore on idle the fuel pressure increases..?
Saturday,09,January,2010,13:44:13:06791
VCDS Version: Release 908.1
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Control Module Part Number: 8E0 910 115 N HW: 8E0 907 115 D
Component and/or Version: 2.0l R4/4V TFSI 0070
Software Coding: 01040003180F0120
Work Shop Code: WSC 00654 210 86464
2 Faults Found:
004506 - Fuel Pressure Sensor (G247): Malfunction
P119A - 001 - Upper Limit Exceeded
Freeze Frame:
Fault Status: 01100001
Fault Priority: 0
Fault Frequency: 1
Mileage: 94720 km
Time Indication: 0
Freeze Frame:
RPM: 772 /min
Load: 15.3 %
Speed: 2.0 km/h
Temperature: 81.0°C
Temperature: 14.0°C
Absolute Pres.: 990.0 mbar
Voltage: 13.970 V
008583 - Bank 1; System too Lean at Idle
P2187 - 004 - No Signal/Communication - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100100
Fault Priority: 0
Fault Frequency: 1
Mileage: 94725 km
Time Indication: 0
Freeze Frame:
RPM: 765 /min
Load: 14.1 %
Speed: 12.0 km/h
Temperature: 87.0°C
Temperature: 12.0°C
Voltage: 13.716 V
Readiness: 0000 0000
Fuel pressure/air leak issue????
2017 Kawasaki Z1000
2014 RS6
2014 S1
2014 RS6
2014 S1
RE: Fuel pressure/air leak issue????
I think I found the fault. Two incorrectly fitted pipes were split:
one between the crankcase and the fuel pressure device on the cylinder head
one between the inlet manifold and fuel pressure device as above.....
I would says thanks for the help but......
instead, thanks for looking....
Car has gained power and torque....
2017 Kawasaki Z1000
2014 RS6
2014 S1
2014 RS6
2014 S1
Users browsing this forum: Google Adsense [Bot] and 30 guests
