B7 Brake swap question
2.7 V6 30v biturbo - 380 bhp
prosty
Post by prosty » Thu Dec 10, 2009 9:35 pm
Hi! I've tried searching but language barrier may be the reason for me not finding anything about this :)
Bare with me.
I'm soon swapping out my b5 brakes for b7 setup. I have calipers, caliper carriers (adapter plates) and B7 365mm rotors. My question is. does the stock b5 adapter plate bolts fit the thread of the b7 adapter plate, and does the b5 brake lines fit to the b7 calipers? If not must I get the b7 stock bolts and hoses (or just get my own braided lines at the hydralic dealer) ?
I hope you understand my questions. Thanks
Markus
Virdee Autos
Trader (Expired)
RE: B7 Brake swap question
Post by Virdee Autos » Thu Dec 10, 2009 10:42 pm
Yes you can use the same bolts.
Ideally best to use brake lines from the B7 too.
Virdee Autos ~ 07950-526592
prosty
Post by prosty » Thu Dec 10, 2009 10:46 pm
Okay thanks for the info! Will call VAG tomorrow for a quote.
midnyite
Post by midnyite » Thu Dec 10, 2009 11:53 pm
For this "caliper carriers (adapter plates)" is this a OEM part? if yes anyone have the part number?
or is this a custom part to have it fitted to a B5?
thanks
prosty
Post by prosty » Fri Dec 11, 2009 8:47 am
I will supply this thread with my adapter p/n later on
Virdee Autos
Trader (Expired)
Post by Virdee Autos » Fri Dec 11, 2009 7:55 pm
AFAIK you can't buy the adapter plate seperately.
prosty
Post by prosty » Sat Dec 12, 2009 9:30 am
Forgot to check the P/N of the adapter plate, but there was a number on it!
THe b5 brake lines worked quite ok, I'm going with steel hoses later but I cannot afford it yet, and I just wanted to put the goddies on so I can start to stop :)
KiwiRS4
Post by KiwiRS4 » Sat Dec 12, 2009 6:50 pm
Hi Prosty, I recently upgraded to the B7 setup. The guys at International Brakes (dts@brakesint.co.uk) made a set of braided lines with SS connectors all for £15+VAT per side. Very professional service and very high quality lines. PM me and I'll send you some pics of the lines that were made.
midnyite
Re: RE: B7 Brake swap question
Post by midnyite » Sat Dec 12, 2009 11:26 pm
KiwiRS4 wrote:Hi Prosty, I recently upgraded to the B7 setup. The guys at International Brakes (dts@brakesint.co.uk) made a set of braided lines with SS connectors all for £15+VAT per side. Very professional service and very high quality lines. PM me and I'll send you some pics of the lines that were made.
you have PM!
midnyite
Post by midnyite » Sat Dec 12, 2009 11:27 pm
prosty wrote:Forgot to check the P/N of the adapter plate, but there was a number on it!
You have PM!
Users browsing this forum: No registered users and 170 guests
