Phaeton front discs
2.7 V6 30v biturbo - 380 bhp
prosty
Phaeton front discs
Post by prosty » Tue Nov 24, 2009 5:56 pm
Hi!
I'm pretty new to this forum and I've read a few threads about putting phaeton TDI discs (360x34mm) fronts and they are a direct swap, is this accurate? from what I gathered when I read the specs on the phaetons is the offset isn't 100% accurate, can anyone confirm that they fit directly or do you have to modify anything to make them fit in the front?
As I have a good price on EBC brakes this would be a real goldmine for me considering VAG charges 800 quid for a new pair of fronts
I hope this thread isn't a duplicate one but I didn't see anyone confirming the fitment in the front, only that the rear fitment was a bit extra work.
Markus
graemep
Post by graemep » Tue Nov 24, 2009 6:42 pm
They are a swap for the B7 RS4 disks but as the offset is different, you need to swap the bells from the old disks
ollys
Post by ollys » Tue Nov 24, 2009 6:59 pm
graemep wrote:They are a swap for the B7 RS4 disks but as the offset is different, you need to swap the bells from the old disks
I have these on my RS6 / B7 RS4 set up. I swapped over the bells from the B7 discs to fit the Phaeton ones - they are 365 mm not 360mm
prosty
Post by prosty » Tue Nov 24, 2009 8:33 pm
Okay so you cannot use them for the b5?
graemep
Post by graemep » Tue Nov 24, 2009 9:36 pm
Not with the standard setup, but they are an option for anyone with the B7 setup.
JHMotorosports also produce a replacement which uses the original bell from the B7 discs.
GDS968
Post by GDS968 » Wed Nov 25, 2009 9:49 am
There is a 360mm version of that disk.
prosty
Post by prosty » Wed Nov 25, 2009 7:47 pm
That was the one I meant, does that one fit
GDS968
Post by GDS968 » Thu Nov 26, 2009 10:58 am
Not on a B5 standard setup, different offset I believe which is a bugger!!!!
don
Post by don » Fri Nov 27, 2009 12:18 am
If you want a more affordable disc replacement for the b5 RS4 have a look at DBA discs, there are a few posts about them if you do a search.
prosty
Post by prosty » Sat Nov 28, 2009 9:32 pm
Got a webpage for DBA? I'm also looking for rear discs too. Not a good month this :)
don
Post by don » Sun Nov 29, 2009 11:19 pm
prosty
Post by prosty » Mon Nov 30, 2009 10:28 am
Thanks Don. Is there any supplier of rear discs too? DBA only had fronts
GDS968
Post by GDS968 » Mon Nov 30, 2009 4:48 pm
I have emailed DBA a million times, they don't ssem to be interested as I have not had a response! The uk importer told me to ask them directly as they have never come into the uk for the RS4!!
Users browsing this forum: No registered users and 65 guests
