Relay clicking without following faults
2.7 V6 30v biturbo - 380 bhp
Kveite
Post by Kveite » Tue Nov 10, 2009 7:48 am
I haven't found out what it controls. It clicks unsystematickly, but only when the car is moving and not when accelerating or braking. It never clicks when the engine is pulling the car as when driving up hill. But if I press down the clutch while moving or let go of the accelerator, or just keeping a steady speed on a flat road, it starts clicking.
The relay does not click when pressing the brake paddle either. This is more consistant with just a light pressure on the paddle will make the relay stable.
It dosen't matter what lights are on, if I am using the cruisecontrol or anything else. And I don't think its a loose connection as it doesn't matter if I am turning quickly back and forth.
Anybody got a clue what relay it might be?
It's a bit hard to locate as the car has to be moving and the relay is about behind the steeringwheel.
ollys
RE: Relay clicking without following faults
Post by ollys » Tue Nov 10, 2009 1:42 pm
I would be interested in the answer to this - definitely got a relay clicking from the brake pedal as it goes away wiht light pressure.
Anyone?
dace
Post by dace » Tue Nov 10, 2009 3:06 pm
I am getting exactly the same thing from my acceleartor. Up to 2,000 rpm it clicks every time you accelerate or deccelerate? It is a very distinct relay click as mentioned...
taclaa
Post by taclaa » Tue Nov 10, 2009 6:10 pm
iirc there are a few relays to the right of the steering wheel just above the little cubby hole, if its around there im sure a process of elimination of what those relays do.
It may sound silly but its not your keys knocking on the steering cowling? (just a thought)
Kveite
Post by Kveite » Wed Nov 11, 2009 9:16 am
Has anyone got a list over relays and function of them?
I have a degree in electronics and knows how a relay sounds like :) And I don't have any keys attached to the carkeys, so that is one possibility being eliminated..
Users browsing this forum: No registered users and 93 guests
