RIDE HEIGHTS ?
philroach
RIDE HEIGHTS ?
Post by philroach » Mon Nov 02, 2009 9:33 pm
Having had H&R's for a while now , am looking at raising it a little at the rear
based on empty car , 1/2 tank petrol , level ground , and 35 profile tyres....
Also appreciate difference between DRC , PSS9's , H&R's etc but am interested in difference between front and rear , as much as actual heights from road to arch
I am currently(H&R's) : rear 642mm , and front 654mm
Johnny11 (DRC) is : rear 685 , and front 662
what have you lot got ????
also , do you need special tools to adjust H&R's , or just the right size spanners , left all my stuff up at the Grizzmeisters when he fitted them
amulet-s6
Post by amulet-s6 » Tue Nov 03, 2009 1:17 am
philroach(H&R's) : Front 642mm, Rear 654mm
Johnny11 (DRC) is : Front 662mm, Rear 680mm
amulet-s6 (Stasis CO) Front 668mm, Rear 678mm 265/35/19
philroach
Post by philroach » Tue Nov 03, 2009 4:16 pm
thanks amulet-s6 , any one closer than Kansas with a tape measure ????
Daveperc
Post by Daveperc » Tue Nov 03, 2009 8:33 pm
There was a thread on DRC not that long ago with a whole lot of heights in it - should be easy enough to find.
Right now my 6 is parrked on a steep slope, on mud, it's dark and raining.....
jd_hants
Post by jd_hants » Tue Nov 03, 2009 8:38 pm
Had DRC replaced couple months ago. Now front is 672mm, Rear is 688mm
philroach
Post by philroach » Tue Nov 03, 2009 9:33 pm
jd hants ( DRC ) :Front 672mm , rear 688mm
philroach
Post by philroach » Wed Nov 04, 2009 5:52 pm
looks like about 10-15mm higher at the back should be there or there-abouts , come on Grizz and Mooch , what are your measurements- car that is , nothing else thanks Mr M !
Cornishmoocher
Post by Cornishmoocher » Thu Nov 05, 2009 10:09 pm
As per PM, mine from centre to arch 320 rear and 330 front.
As if I would tell you how big my knob is anyhoo.......
It's all Bollox.
philroach
Post by philroach » Fri Nov 06, 2009 10:05 am
so your set up is lower at the back then ? did u measure road to rim ? should be the same difference i suppose...
Cornishmoocher
Post by Cornishmoocher » Fri Nov 06, 2009 10:18 am
I set mine up to cope with the farm lane and the crap cornish roads!
It's all Bollox.
buzzard666uk
Post by buzzard666uk » Fri Nov 06, 2009 12:48 pm
if PSS9's fitted to C5, with C5 wheels but with 275/30 19 Goodyear F1's, what would be the recommended ride height ? and measured from where to where ?? and with assumed # of passengers ?? thanks...
Cornishmoocher
Post by Cornishmoocher » Fri Nov 06, 2009 2:27 pm
How fat are your passangers?
It's all Bollox.
buzzard666uk
Post by buzzard666uk » Fri Nov 06, 2009 6:32 pm
Cornish, not a case of being fat, but a question from someone that is new to this stuff..... I saw it as a reasonable question.... ie if you lower to whatever for solo drive, does one then have to adjust if 4 people in the car !!!
Cornishmoocher
Post by Cornishmoocher » Fri Nov 06, 2009 7:10 pm
It was a joke! :roll:
Personally, I have no knowledge of the Ps kits, but would imagine that the ride hight is fairly standard among those who have gone for coil overs- a balance between comfort and handling, so if you take an average of what people here are running I don't think you will be far out.
Unless you track your car and are a profesional driver, i dont think that the passangers (even if feckin GYNORMOUS) will make a huge difference.
HTH
Mooch
It's all Bollox.
Cornishmoocher
Post by Cornishmoocher » Fri Nov 06, 2009 7:12 pm
Mine BTW road to arch is 630 rear and 640 front. (on H&R's)
It's all Bollox.
Users browsing this forum: No registered users and 591 guests
