Starting in the morning
MartinRS2K
Post by MartinRS2K » Mon Nov 02, 2009 4:00 pm
The car sometimes has an issue when starting first thing in the morning.
Car is an S4 B6 (2004) and we have just changed the ignition switch which hasn't cured the fault :(
Sympton : When cold (and only the first time in the day) when I turn the key radio,lights etc. all work but the car doesn't start. If I hold the key in the start position for a couple of seconds it soemtimes fires up. Otherwise I have to leave it for a few seconds and try again (sometimes without success so I have to leave then repeat the process until it starts).
Once started there are no issues for the rest of the day, but in the morning I have the dreaded wait again!!!
Any sugestions appreciated?
Audi A4 2.0 TDi Avant - B8 - Brilliant White
Audi RS4 Avant - B9 - Navarro Blue
Audi A6 2.5 TDi Avant - C5 - Atlas Grey (Towing vehicle for my RS2000 and Ifor Williams Trailer)
Ford Escort RS2000 Custom - 1976 - Signal Green
Post by chunky79 » Tue Nov 03, 2009 8:09 am
People have had the starters packing up and doing this. Take a look ine the B6 S4 forum.
Dunc
PetrolDave
Post by PetrolDave » Tue Nov 03, 2009 7:49 pm
Sounds like a faulty solenoid on the starter motor. It tries to pre-engage the starter gear in the flywheel before engaging the actual starter motor, but if it can't pre-engage the gear it doesn't energise the starter motor.
elmo
Post by elmo » Tue Nov 03, 2009 10:29 pm
I had the same problem about one month ago with exactly the same symptoms.
It turned out to be a combination of the starter motor and the ignition switch. Since you have sorted the ignition switch, it only leaves the starter. Mine went up in a cloud of white smoke one morning after I held the key over for 10 seconds after it wouldn't start.
It's a funny situation because for the rest of the day the car would start fine. I had also replace the battery with no effect.
Since replacing the starter motor and ignition switch, I have not had the problem since!
04 Audi S4 B6 Moro Blue Saloon
Peugeot 205 MI16 with twin 45's for the track (in the Garage)
Honda Prelude 2.2Vti - Gone but not forgotton
TR7 - well rid of
Triumph Spitfire - student wheels
MartinRS2K
Post by MartinRS2K » Wed Nov 04, 2009 11:13 am
Thanks for all the help and advice. Looks like it is a new Starter Motor that is needed. Hope it's coverd under the warranty :)
Lion
Starter
Post by Lion » Tue Nov 10, 2009 10:42 am
Can I suggest you replace the starter Interlock relay under the ECU chamber first as a cheap option. I had my starter motor replaced @ £350 and it didn't solve the problem, although at first it was better. The relays are affected by the cold.
Lion
MartinRS2K
RE: Starter
Post by MartinRS2K » Tue Nov 10, 2009 6:56 pm
Hi Lion
Thanks for the info. The warranty company has changed the starter motor under warranty (£250 bill for them) and the car seems to be starting perfectly now. 'Fingers Crossed'
Martin
Return to “DTC / VCDS”
Users browsing this forum: No registered users and 6 guests
