Potentially thinking of getting a set of 18" LMs. Anyone know how they would look on a Noggy RS4?
Had a search but can't find a pic of that combo!
Olly
LMs on Noggy
- rhunter203
RE: LMs on Noggy
There reps but you'll get the idea http://audisrs.com/about7160.html
MRC 490BHP 500ft/lbs RS4
3.6 0-60 12.04 1/4M
3.6 0-60 12.04 1/4M
Olly, what brake setup you got on your RS? Also, what spec LM you thinking of going for?
Reason I ask is I was told that if you have the B7 or RS6 setups, the barrels of an 18" will not clear the brakes!
Nils
Nils
Instagram : n_i_l_s
and if anyone would know something so boring then Nils is your man!N11LS_J wrote:Olly, what brake setup you got on your RS? Also, what spec LM you thinking of going for?
Nils
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
C7 - RS6
C6 - RS6
B5 - RS4
philipwalker
- 5th Gear
Thanks Guys (Great advice!) - just to be clear these are LM127 18 x 8.5 ET30. Would have needed spacers anyway but with the B7 set up I have (front and rear) I am guessing more than a 12mm spacer will be required?philipwalker wrote:As Nils suggests
The 18" LM does not have the caliper space required by larger calipers, even 9x19 LM will require extra spacing to clear the B7 calipers.
Not keen on running wide spacers!
Olly
