Remote clock disappeared after battery disconnect.
Post by Shoppinit » Sat Oct 10, 2009 6:23 pm
My RS6 has always set the time on its own until the other day when I disconnected the battery. I don't get the little antenna logo next to the clock any more.
I've gone through the instrument cluster and everything is coded correctly as far as I can tell. I tried turning it off and back on again in adaptation, but to no avail:
A19,12,xxxx?: Remote Clock (0 = inactive / 1 = active)
Address 17: Instruments Labels: 4B0-920-xxx-17.lbl
Part No: 4B0 920 937 B
Component: KOMBI+WEGFAHRS. VDO D12
Coding: 01084
Shop #: WSC 08336
WUAZZZ4B43N901198 AUZ7Z0B2189001
No fault code found.
Any ideas? Thanks.
Return to “DTC / VCDS”
