ESP Light flashes very regulary...WHY?
2.7 V6 30v biturbo - 380 bhp
JesseJonesJackson
Post by JesseJonesJackson » Fri Oct 02, 2009 6:09 pm
Hi Everyone,
I am the proud new owner of one of the 40 Black RS4 B5 :D and I need a bit of help and advice?
1) Has anyone had an issue with the ESP light coming on at seemingly regular intervals yet the road conditions are perfect?
I could understand it if I was a snow stage at the WRC but this is under acceleration on dry roads in 2nd/3rd/4th!
2)The gear stick feels loose, lots of left to right movement when in gear...is this normal?
3) and last, The handling I would describe as 'average' at best, I came of Evo and Impreza but the RS4 feel loose and somewhat tail happy. Will Anit-roll bars sort this out?
Any ideas comments gratefully recieved.
Many thansk
JJJ
jimbo1234567
RE: ESP Light flashes very regulary...WHY?
Post by jimbo1234567 » Fri Oct 02, 2009 8:01 pm
esp is probably due to a dodgy abs sensor thats telling the ecu that the wheel is turning faster or slower than the rest causing the esp to kick in. log the wheeel speeds on vagcom to find the culprit.
pop the gearstick gaitor surround off and check all the nuts are tight
uprated antiroll bars will make the car much flatter. go for the 21mm rear arb if going h+r and set it to stiffest and you will need some subframe strenghening brackets from mrc. alternatively go for the hotchkiss arbs which have a set of strenghening brackets in the kit, theres a group buy on srs at the moment if you want to put your name down and get a discount. :nogarors4:
JesseJonesJackson
Post by JesseJonesJackson » Fri Oct 02, 2009 8:12 pm
thanks Jimbo,
How do you log the speeds with Vagcom please?
its going to MRC next week, so which arb's do they fit? are the strenghtning brackets additional to the drop links?
RS4 B5 Black - MRC Custom Map, full Milltek system and downpipes, H&R ARB
EuroSag
Post by EuroSag » Fri Oct 02, 2009 8:43 pm
Mate, the ESP thing is probably telling you that you have odd tyres fitted. Check they are all the same and of not, change 'em. :thumbs:
Porsche 997 GT3 - 2010/60
Porsche 997 GT2FS - 2008/58
Peugeot 205 1.9 GTI-S - 1991/J
Audi B7 RS4 Saloon - 2007/07
Audi Q7 3.0TDI - 2011/11
Alfa 147 GTA - 2003/53
Ford F150 Raptor - 2012/62
neckarsulm
Post by neckarsulm » Fri Oct 02, 2009 9:00 pm
I had a spate of this recently, it was verging on the dangerous as I'd cross white line to overtake and ESP would flash!
I thought it was corrosion of the ABS sensor as I had washed the car but not driven it to dry it off.
It got better with use.
MRC did say in another post they had seen this with odd tyres though.
Check your tyre pressures too.
lushman
Post by lushman » Fri Oct 02, 2009 10:24 pm
I had the same problem with the ESP due to tyres. Changed them to Toyo all round problem gone.
I had the Hotckis ARB's fitted and a huge difference was noticed immediately
C7 RS6 coming soon
2006 B7 RS4 Avant Sprint Blue & Black Optics - Gone
2000 Avus Silver B5 RS4 - Gone
lengster1
Post by lengster1 » Sat Oct 03, 2009 11:07 pm
ESP is over sensative,if you have a tuned example and are going for a brisk blat then turn it off,the way it cuts power is almost more dangerous than it spinning up the tyres,b5s need work to handle well,std suspension was soft even new and by now will be totally fcuk"d,anti roll bars are almost a must!! a firm yet supple aftermarket suspension kit is the way to get the best out of the car.
rsmonkey918
Post by rsmonkey918 » Mon Oct 05, 2009 11:47 am
Going with Lushman on this in a totally unrelated way!! Running a Brabus Smart with 101bhp and a screw in the O/S rear, usually go down to Micheldever but ended up in a local Kwikfit, who true to form could only source me two Goodyear Eagle GSD3/F1's, so just thought well OK, Iknow they're good because a few Forum members are running them! However, ever since fitting them and taking right handed corners- and mostly not even over-egging it- I get the ESP/ABS light and a really unnerving feeling from the front as if its sliding and braking at the same time.... Assume that me sitting on the right has something to do with it- it never happens on left handers...
Can't fault the grip- it feels really nailed down at the back but my dilemma is that there are only a few fitments for the front and the Yokohama A520's already on and still with plenty of tread were supposedly the sportiest option at the pointy end.....
This phenomenon never happened before, so have to assume its a tyre issue, so check whether your tyres match up- saw one at MRC a few weeks ago with different rubber on every corner......
Regards
Steve
Steve
2000 X RS4 B5 Avus short shift, MTM/full Milltek to 460bhp, 19" Audi split rims/BBS CH's in anthracite, B7 front/rear big brake conversion, H&R ARB's/Bilstein PSS9's/ESP gearbox brace, retrofit RNS-E+Nav, ITG/MRC panel filter
2007 '07 Smart Brabus 101bhp, Bilsteins, Bentley Silverlake
2007 '56 Aprilia RSV Factory for some weekends
2004 '53 Honda Rune NRX1800 for other weekends
Users browsing this forum: No registered users and 176 guests
