spark plugs
spark plugs
Hi guys, been doing some research using the search button, but just want to clarify a few things
I know the spark plug used in an RS4 is NGK PFR7Q
however there is also NGK BKR7EIX which is apparently the same plug
http://www.sparkplugs.co.uk/pages/prici ... rs-ccp.asp
if you view the link how comes the PFR's are more expensive? (even with them being platinum/iridium) - the BKR's are iridium but cheaper
i thought it was the other way around, if someone can clarify for me would be great as i need to order these tommorow asap
RE: spark plugs
update - have been advised to use the bosch F5DPOR plugs as they are tried and tested to be the best out there when running higher power
Avus B5 RS4, Miltek down pipes/No cats/Miltek Cat-back, Wagner uprated SMIC's, short shifter, B7 brakes, Phaeton brake ducts, H&R ARB's, H&R Coilovers, AWE DTS, MRC custom Remap + water meth injection = BIG GRIN on my face with poo in my passengers pants
**Now with a Carbon roof**
'Build the best and the rest will follow'
RE: spark plugs
http://www.rs246.com/index.php?name=PNp ... ic&t=78619grizz wrote:Stick with NGK , I've had 2 cars with bosch plugs that have failed that resulted in massive engine failure ...
RE: spark plugs
cheers shoppinit.
i spoke to doug/virdee regards this and they advised the BOSCH is the only way forward on this car. i know alot of other members use bosch too
RE: spark plugs
OK Cool
Jules, i was confusd when searching for plugs too,
1 member said NGk
Virdee. DOUG. and another member said bosch so kind of took there advice,
when i took the old plugs out they were bosch also
the part no. is Bosch F5DPOR
pm virdee for a good price as he can get them at a good rate
I paid 51 GBP for 6
1 member said NGk
I paid 51 GBP for 6
- 5th Gear
bosch are the best ones out there. cheapest isnt best
665 bhp + 586 lbft...
Then why are the OEM plugs for the RS6 NGK's? Despite everything else being Bosch. Audi chose NGK over Bosch which is pretty rare for Audi. They like to keep it German. When's the last time you saw Magnetti Marelli on an Audi?
