Indicators
MartynC
Indicators
Post by MartynC » Sat Sep 19, 2009 8:43 am
From time to time the indicator 'clicker' unit on my 6 continues to click rapidly after I've cancelled the indicators. Goes at about double speed, sounds like they do if a bulb's gone but the lights don't flash. Anyone else had this?
MartynC :?:
baylissboy
RE: Indicators
Post by baylissboy » Sat Oct 03, 2009 9:21 pm
Normally caused by the indicator relay.
Virdee Autos
Trader (Expired)
RE: Indicators
Post by Virdee Autos » Sat Oct 03, 2009 9:38 pm
Possibly the hazard switch (incorporates relay) or the indicator stalk itself.
Virdee Autos ~ 07950-526592
MartynC
Post by MartynC » Sun Oct 04, 2009 11:52 am
Thanks guys, it went away for a few days but has now returned, It's in for 90K service soon so will mention it then.
MartynC
jd_hants
Post by jd_hants » Mon Oct 05, 2009 11:17 am
Funny enough - my indicators started playing up this morning on the way in to work. I use the stalk and the indicators flash. But now and again there is a double flash and sometimes the flashing stops completely. It affects both sides but doesnt seems to affect the hazards. I am assuming its not bulb-related as its both sides. Presumably this is the flasher relay too. I have an RS6. Do you know if its a single unit/relay and where it is located?
jd_hants
Post by jd_hants » Mon Oct 05, 2009 5:07 pm
Its been answered. Cheers anyway! :-)
kwack
Post by kwack » Thu Oct 08, 2009 10:32 am
Mine sometimes does this as well. Is it the relay and if so where is it?
KWack
MartynC
Post by MartynC » Mon Oct 19, 2009 7:20 pm
Well it wasn't the indicator relay.......indicator stalk assembly on order, bless that warranty!
MartynC
MartynC
Post by MartynC » Fri Oct 23, 2009 2:14 pm
It was the indicator switch....all kinds of clicky fizzy noises from the flasher unit, now OK. Glad it was a warranty item as I guess the switch unit is quite expensive.
MartynC
Virdee Autos
Trader (Expired)
Post by Virdee Autos » Fri Oct 23, 2009 6:52 pm
The stalk for the S3 I did the other day was only £30! Bargain for once!
Return to “Electrical”
