Does anyone know of a fitting guide or has done it already?
My main problem is the 4 white cables which are merked
CAN LOW
CAN HIGH
DAVERPLUS
MASSE
where do they connect to?
thanks
kufatec ima fitting help
RE: kufatec ima fitting help
Daverplus is a +12V switched live
Masse is GROUND
Can high and low are quite explanatory, if you have an RNS-E fitted then use pins 9 (high) and 10 (low) for CAN connections
Masse is GROUND
Users browsing this forum: No registered users and 162 guests
