Front speaker/ door insert problem
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
Nodds
Post by Nodds » Thu Sep 03, 2009 10:46 am
Hi All
The drivers side front speaker (Bose system) sounds as if is blown or maybe just working loose. Can anyone tell me how to get at the speaker mounts, does the grill come off or do you have to take the door card/insert out and if so how ? I Guess the door car pops out, but before i break something trying to remove it i thought i had better ask
Nodds :?
andybnwc
RE: Front speaker/ door insert problem
Post by andybnwc » Thu Sep 03, 2009 10:51 pm
door card has to come off . Little screw inside interior grab handle then plastic insert which screw was holding pops out . behind this are 2 screws remove these. one at each top corner of door card in the door shuts . Then the door car lifts up and off with a tap and a tug . Disconect any cable plugs if needed . Once the door card is removed you can see the sound proof foam remove this and you will see the speaker . hope this helps.
Nodds
Post by Nodds » Fri Sep 04, 2009 1:37 pm
I knew there would be some hidden fixings
