Noob - How to fit LEDs to the RS4 B7 DRLs
what kind of LED lights & resistor do i need ? voltage, ohms ? where can i buy them ?
do i need to tinker with VAG COM too ?
help pls.
cheers
help pls.
cheers
RE: Noob - How to fit LEDs to the RS4 B7 DRLs
Load resistors from RS components as follows.
RS Stock No. Qty Unit Price Goods Value Description
615-0505 2 £1.99 £3.98 HS50 Al house wirewound resistor,24R 50W
160-786 2 £1.55 £3.10 HS25 Al house wirewound resistor,68R 25W
Running Total £7.08
Delivery charge £4.95
VAT £2.11
Order total £14.14
LED info to follow.
Running Total £7.08
VAT £2.11
Order total £14.14
LED info to follow.
Sorry, but what is the difference between side light LED and DRL LED ?
just to check whether i got it right...
if i were to go for the side light LED (501/194/T10 New Mini Light Tower 15 Leds Xenon White), then i need the HS50 Al house wirewound resistor,24R 50W resistor?
and same goes with the DRL LED
DRL LED (V-LEDS HID WHITE 60 M-SMT PARKING BACK-UP LIGHT BULBS 1156) with HS25 Al house wirewound resistor,68R 25W resistor?
is that right?
thanx
is that right?
thanx
The search button is your friend
There is an older thread about this arround here, just search drl led . A bit of advice, don`t put the resistor on the back or inside of the headlight cap, it will melt right through it. Just put it on the back of the aluminium (or is it steel? ) piece that holds your hood and the upper intake piece so it has some cooling and it doesn`t melt .
Users browsing this forum: No registered users and 468 guests
