Door not closing properly?
4.2 V8 40v Naturally Aspirated - 335bhp
s6
Post by s6 » Mon Aug 31, 2009 8:58 pm
Hi
My S6 drivers door isn't closing properly, need to adjust the plate I reckon.
Does anyone know what type screwdriver it is?
no_RS
RE: Door not closing properly?
Post by no_RS » Mon Aug 31, 2009 9:33 pm
Believe they are Torx headed screws.
s6
Post by s6 » Tue Sep 01, 2009 10:00 pm
thanks, any idea what size?
Overhauled S6 (2000) 4.2 V8 340bhp Goodwood Green
New Gearbox, New Exhaust System, New Brakes and sweet at last!
s6
Post by s6 » Tue Sep 01, 2009 10:07 pm
12 point spline is the term I've just been told
s6
Post by s6 » Sun Sep 20, 2009 4:54 pm
Thanks got those, just tricky getting the adjustment right!
coullboy
Post by coullboy » Mon Feb 01, 2010 12:01 am
I think you will find its not the closing plate thats needing adjusted. Mine has its moments too and I suspect its the lock assembly its self. Mine freezes when its cold causing the door to bounce open totally. Other times it almost closes but not quite. I found lots of WD40 into the lock helps. Give it a try.
This is a very common fault on S6s and A6s in general.
technics100
Post by technics100 » Wed Feb 17, 2010 4:21 pm
I would just clean the lock out with WD-40 and then use a very light spary grease to keep it lubed and free from sticking.
2000 Goodwood Green S6 4.2 V8 340bhp.
coullboy
Post by coullboy » Wed Feb 24, 2010 12:20 am
Guys, its £114 for a new lock unit from Audi, just bought it today.
will let you know how easy it is to fit!
snowman
Post by snowman » Fri Jun 25, 2010 12:42 pm
If anyone else has this problem also worth looking at this from HJ's website:-
"Lock of front passenger door can fail. According to J.A., the fix is to remove 3 screws that hold the door trim on, then remove or stick back the sound insulation inside the door to the outer door skin, making sure that none is jammed in the lock mechanism. In 95% of cases the door lock will now lock and un lock on demand. Total cost 15 minutes time."
Hope this helps anyone with this problem.
Return to “S6 (C5 Typ 4B) 1999-2003”
