brake's a few questions
after selling a few old bit's from my gtr days i've got some money to spend on a upgrade, i was after a b7 set but can't find a set anywhere now i want one. so i have been looking at other set's but most manufactures only go as high as 6 pot calipers and 330mm disc's.
So my questions are what are the sizes of the pot's on the b7 rs4 set's? so i can figure out actual force area applied and compair to others.
How easy are the b7 rs4 ones to fit? is it just straight bolt on?
And has anyone else had expereance's with both b7 rs4 set's and an aftermarket set?
How easy to fit and good are the porsche setup's i've heard about?
I apolgise for my spelling, but it's never been to good.
done the jap thing, trying the euro thing!
RE: brake
Go For the b7 , bolt on and very good..
Unit 20
0151 3366888
0151 3366888
RE: brake
Aren't Porker ones similar to the B7 RS4 ones? But need a carrier to fit?
B5 RS4 - now sold.
B5 RS4 - now sold.
RE: brake
Brembo make calipers for the RS4 & Porsche, so they are similar. It comes down to the quality of the discs and temp range of the pads. The drilled RS4 discs are a PITA to keep the holes clean, so you might want to look at alternatives from the Audi stable (speak to Grizz). The RS6 pads are great for fast road use if you go down the B7 caliper route.
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
RE: brake
Phaeton's are presumably same size, cheaper?
B5 RS4 - now sold.
B5 RS4 - now sold.
Re: RE: brake
Yes same size and around half the price! Not drilled, however made by the same manufacturer as the B7's, in Italystumpy67 wrote:Phaeton's are presumably same size, cheaper?
RE: Re: RE: brake
So a good swap then! Will have to look into having them too !!
B5 RS4 - now sold.
B5 RS4 - now sold.
Re: RE: Re: RE: brake
You will need the B7 "hats" though as the Phaeton's are different. 10 minutes to swap over.stumpy67 wrote:So a good swap then! Will have to look into having them too !!
