High Maintenance
2.7 V6 30v biturbo - 380 bhp
Contigo
High Maintenance
Post by Contigo » Fri Aug 21, 2009 2:32 pm
Does anyone find they are constantly checking their cars or scheduling time for replacing bulbs, tyres or whatever else goes.
Had two new tyres last month and tracking sorted, then Boot actuator went and this morning Brake light warning comes on.
I'm thinking of quitting my job just to keep on top of the machine! :D
Sell up and get a Mondeo TDci? No way!!!!
2001 Avus Silver RS4 B5 60k on clock, MRC Custom Remap, Sunroof, Bluetooth prep
2006 Daytona Grey RS4 B7, RNS-E - SOLD
2006 BMW M6 - GONE
Contigo
RE: High Maintenance
Post by Contigo » Fri Aug 21, 2009 4:29 pm
Just done brake light bulb
Got the thermostat, Both Lambdas and EGT to do now.
2006 BMW M6 - GONE
Blue_Thunder
Post by Blue_Thunder » Fri Aug 21, 2009 5:44 pm
It's never ending with these cars.
These sites would be pretty quiet if they weren't though!
lengster1
Post by lengster1 » Fri Aug 21, 2009 6:15 pm
If its the upper lambdas your doing get yourself a 22mm halfords combi ring spanner and be prepared to cut it down its a pig of a job
rtd
Post by rtd » Fri Aug 21, 2009 6:43 pm
when it rains it pours!
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
Contigo
Post by Contigo » Fri Aug 21, 2009 7:31 pm
Getting them done under Warranty so no probs there, they wont cover the EGT or MAF so will do the Lamdas first to see if that fixes it. It runs fine at the mom but best to not have any fault codes you know.
2006 BMW M6 - GONE
mad-for-tar
Post by mad-for-tar » Fri Aug 21, 2009 10:21 pm
Never ending alright.... mines been laid up since the day I bought it...over 6 weeks ago, due to travelling abroad and personal circumstances so only been getting on top of things this week. Alternator packed up the day I picked it up so I knew thats the start of the deep pockets! :(
So far this week:
> 1 new alternator fitted
> Battery recharged
> Bulkhead tray drains modified
> Found 2 loose spark plugs, all 6 checked and silicone grease applied to boots of the coil packs for insulation.
> Small plastic valve for crankcase ventilation repaired (like a one way valve type thingy, was blowing oil vapours straight at the bulkhead :shock: )
> Wiper arm shafts checked for stifness/seizure, removed cleaned and greased.
> Seized boot lock barrel removed, dismantled and freed out.
> Bluetooth handsfree kit rewired as was never done properly upon installation.
To go in tomorrow:
> Pair of 710N's, coolant temperature sender and after-run mod.
> X contact relief relay, #370 (blew it in process of rewiring car kit...doh!)
Hopefully after that, I'll get to enjoy it for a few minutes before something else gives up! :lol:
There are 2 tools you need in life: WD-40 and Duct Tape.
If it moves and it should'nt, use the Duct Tape
If it doesn't move and it should, use the WD-40
Contigo
Post by Contigo » Tue Aug 25, 2009 7:43 am
Feel for you mate, the day before the wedding the boot wouldn't open properly or close (lock) so had to go to the Stealers and have it bodged so that the key could open and close it. Took it to them on Monday and they replaced the Actuator.
2006 BMW M6 - GONE
ShaneyB
Post by ShaneyB » Tue Aug 25, 2009 10:23 am
You're certainly putting me off getting a B5........
Shane
Current
2017 C7 Nardo RS6 Performance
Gone:
C43 AMG Coupe
Black E92 M3
Daytona B7 RS4 Saloon
B6 S4 Saloon Tip
B5 S4 Avant
8L S3
Lexus IS 200
Vauxhall Cavalier 1.8 lsi
Vauxhall Astra 1.6l
Fiat Uno Turbo
Fiat 127 Sport
Ford Cortina MK5
Opel Kadett
quattrokid1
Post by quattrokid1 » Tue Aug 25, 2009 10:59 am
I think I'll go and wrap ours in cotton wool!!
no problems here apart from the ones that came with the car.....
sorted now and touch wood its been fine since.
Ours gets an easy life so perhaps we're lucky?
Misano red B5 RS4 710 D/V's SERVICED BY EL GRIZZMO:).... Wife's !!
Tornado red WR quattro :):)
UrS4 saloon auto:) resurected by Unit20
Audi S3 8L Imola yellow
Audi B6 S4 Cabrio SOLD :( :(
Audi 100 2.2E SOLD
Audi 80 cabrio 2.6 V6 (SOLD)
Audi 90 quattro SOLD
andream88
Post by andream88 » Tue Aug 25, 2009 11:36 am
we all should replace the 2,7tt with a turboed VR6.
Rs4 b5 06/2001
custom remap - KW V3 - Hotchkis Sways - ASP DTS with poly mount - 034 Street Mounts + Snub with bracket - Apikol rear diff mount and bushes - Gutted precats - DUH Fmic kit - 360x32 floating discs+brembo 6-pot at the front - 710Ns - OEM 18 Hard wheels - JHM shifter/linkage/spring etc - Podi.ca Boost Gauge - Powerflex Bushes - Afterrun mod -
mad-for-tar
Post by mad-for-tar » Tue Aug 25, 2009 11:52 am
Shagga wrote:You're certainly putting me off getting a B5........
Dont let that ruin it for you....you buy one in the knowledge that you WILL at some point have to fix some of the common problems and expect for the worst to happen. But one thing I will say for sure is by God, the thrill of driving the damn thing certainly outweighs all the bad points. Do it...you wont be sorry! :biggrin3: (Just my 2p worth!)
ShaneyB
Post by ShaneyB » Tue Aug 25, 2009 12:03 pm
I'm half thinking that anyway as I had all similar issues with my mapped B5 S4. I'm just trying to work out if I should go for the B5 or B7 RS4 now. Not a bad dilemma I suppose.
Shane
Current
Gone:
C43 AMG Coupe
Black E92 M3
B6 S4 Saloon Tip
B5 S4 Avant
8L S3
Lexus IS 200
Vauxhall Astra 1.6l
Fiat Uno Turbo
Fiat 127 Sport
Ford Cortina MK5
Opel Kadett
Contigo
Post by Contigo » Tue Aug 25, 2009 6:15 pm
B7 if you want less of a headache and more of a marvel! Bear in mind though that most of them are coming to the end of their 3yr manufacturers warranty and as such couild stat costing you. Try to buy one with 1 yrs extended Audi warranty or go with one of the aftermarket warranties on it.
2006 BMW M6 - GONE
stumpyrs4
Post by stumpyrs4 » Tue Aug 25, 2009 9:57 pm
B5 every day.
Since owning the car for a total of 4 weeks now? I absolutely love the thing. Having been released from it's shackles by Dougal, it's even better.
My 2penneth worth as well...
:boots: :boots: :boots:
B5 RS4 - now sold.
Users browsing this forum: No registered users and 140 guests
