Gear knob removal
RE: Gear knob removal
push the lower part of the knob down (trim around the stick) then pull out the button and secure with a cable tie,then a good tug and it should come off,be very carefull with it though if you let the button go back in its a real pain in arse to get back on (the button mechanism has a bell crank in it),hope that helps
1999 S4 bi turbo imola yellow,grey pearl wheels,now with KO4's.
2001 A6 avant 2.5 tdi,the work horse
Cheers for that - Ill take a look when I dont need the car for a bit (just incase)
- martinjpainter
Re: Gear knob removal
I tried to remove my gear shifter on my C6 RS6. I tried pulling the push button out and lifting the knob, but it would not move.
Any clues?
Any clues?
found this on you tube but for a B6 A4 principles should be the same
https://www.youtube.com/watch?v=ojObZBmjDiI
2018 B9 RS4 Navarra Blue
2013 B8 RS4 Sepang Blue
2007 B7 RS4 Avant Sprint Blue
2001 B5 RS4 Nogaro Blue
1993 B4 S2 Avant laser Red
Users browsing this forum: No registered users and 58 guests
Pictures
