Thoughts on fitting smaller tyres
Out of curiosity,what do you think would be the downside of fitting smaller tyres,The alloys i am running at the minute are fitted with 265/30/19.
Ive just had a look at other options of wheels and have seen a few sets that are 8.5 inch wide.As these are narrower what would it be like with say 235/35/19s. Apart from less rubber on the ground any other downsides.
Also what width tyre could i got op to with a 8.5 inch alloy.
Thanks in advance
Thanks in advance
RE: Thoughts on fitting smaller tyres
On the plus side it would be a lighter wheel tyre combo so less unsprung weight and therefore improvement in ride/handling.
Also a bit less tramlining from the narrower tyres.
The standard 18.8.5 tyres uses 255 profile.
B5 RS4 in Avus, Custom 3" down pipes 100 cell cats, MRC custom map, ITG filter, HR antiroll bars, Poly bushes, B7 calipers and discs, ESP DTS, TV, Sat Nav and sun roof.
18-inch is my preference, so no downside going from 19
On a narrower tyre in regards to the rim, 225/40/18 is about the minimum for standard one - and it will look funny. Have not tried booting with this kind of setup on track so cannot tell how it would behave under the car.
As obvious, 255 is good for 8.5.
Jules, you need to keep the rolling radius the same, for example, if you go narrower, you would have to increase profile i.e 40/45mm...
If you want to keep low profile with narrower width, the only downside I can see really is that your speedo will be out quite a bit, there are tyre calculators on the web to help you toy with different sizes, have a play with sizes on here...
http://www.tyresave.co.uk/tyresize.html
maybe sticking to 255 as a minimum is best?
Nils
Nils
Instagram : n_i_l_s
- Virdee Autos
- Trader (Expired)
On a 8.5J I certainly wouldn't go for a tyre less than 245, especially on a car like the RS.
All IMO of course!
All IMO of course!
Virdee Autos ~ 07950-526592
Agree!Virdee Autos wrote:On a 8.5J I certainly wouldn't go for a tyre less than 245, especially on a car like the RS.
All IMO of course!
Forgot one obvious downside; going for a narrower tyre means "faster" or "lighter" steering feel, depending on how much was the difference. Less resistance you see... Like it more steady, myself.
Would keep the circumference about the same too.
Though the 19-inch "hint" was taken, you can "play" with the visual outlook of filling the arches to some extent with ride height.
