Error on Vagcom
Kingkong
Error on Vagcom
Post by Kingkong » Mon Aug 03, 2009 9:25 pm
Hooked up the cable and got a couple of error, anyone seen these before? Can't seem to find much on the web
1 Fault Found:
008213 - Intake Manifold Flap Position Sensor (Bank 1): Implausible Signal
P2015 - 008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 1
Mileage: 14605 km
Time Indication: 0
Freeze Frame:
RPM: 2993 /min
Load: 26.7 %
Speed: 114.0 km/h
Temperature: 90.0°C
Temperature: 20.0°C
Absolute Pres.: 990.0 mbar
Voltage: 13.843 V
1 Fault Found:
01134 - Alarm Horn (H12)
37-10 - Faulty - Intermittent
any help would be appreciated
2007 RS4 (B7) Avant, Daytona grey
PetrolDave
RE: Error on Vagcom
Post by PetrolDave » Tue Aug 04, 2009 7:01 pm
They're both intermittent so reset them and see if they come back.
P.S. Any chance you could make your avatar smaller - it takes up a hello of a lot of the screen and reduces the usable width of the screen?
Return to “DTC / VCDS”
Users browsing this forum: No registered users and 40 guests
