Nearly failed MOT on emissions?!?!
paulo
Post by paulo » Fri Jul 24, 2009 8:49 pm
Today I had to take my car for its first MOT. Everything was going well (as expected) until the emissions test.
The Lambda was reading high (by quite a bit).
The guy ended up leaving it, doing so other things, and then retesting it. Luckily, everything was ok the second time around.
Now, should the emissions still be acceptable when running in sports mode? The reason I ask, was that before the test, the guys where playing with the sports mode, and revving it a bit. Could this have thrown the readings, even after putting back to normal mode before the test?
Anybody else had problems with emissions?
Paul
PetrolDave
RE: Nearly failed MOT on emissions?!?!
Post by PetrolDave » Sat Jul 25, 2009 11:51 am
I had my first MOT last week and sailed through the emissions tests no problem.
Revving it should, if anything, be a good thing since it will clear out any soft build-ups in the engine/exhaust (remember that the MOT test for a diesel REQUIRES the engine to be run to the limiter before the emissions tests are made to clear out smoke particles etc.).
S2tuner
Trader (Expired)
Post by S2tuner » Sat Jul 25, 2009 6:51 pm
Cats were probably cold, which explains why the car failed on the first test.
scaghead
Post by scaghead » Sat Oct 09, 2010 11:38 am
my motor has just failed the emissions test on lambda.....pass is min of 0.970 to max 1.030..my reading was 1.9 to 2.04 slightly high :roll: ..... co reading was 0.02 and HC was 31 ppm these two readings were fine... any ideas fellas
pad125
Post by pad125 » Sat Oct 09, 2010 5:20 pm
Scaghead, Is it in with the dealer for the MOT? They'll probably point to the Mass Air Meter first and want to change that, after that.................it could be a world of hurt!! :(
neckarsulm
Post by neckarsulm » Sat Oct 09, 2010 5:26 pm
scaghead, I'm surprised that it's running so lean and yet spot on with CO and HC
karl
Re: RE: Nearly failed MOT on emissions?!?!
Post by karl » Sat Oct 09, 2010 7:41 pm
S2tuner wrote:Cats were probably cold, which explains why the car failed on the first test.
Cats? What Cats?! :D
scaghead
Post by scaghead » Sat Oct 09, 2010 8:00 pm
neckarsulm wrote:scaghead, I'm surprised that it's running so lean and yet spot on with CO and HC
yes that is the thing that is a bit confusing.. at low rpm it was at its worst 2.04 as it was reved up to 4000 rpm it feel a little to 1.94.. am i right in thinking if it was the lamda sensor it would mess with the co reading??
scaghead
Post by scaghead » Sat Oct 09, 2010 8:07 pm
pad125 wrote:Scaghead, Is it in with the dealer for the MOT? They'll probably point to the Mass Air Meter first and want to change that, after that.................it could be a world of hurt!! :(
patrick i got the mot done at a friends garage.. the world of hurt dont sound to nice :) i have had it re-mapped but that was nearly two years ago so i have ruled that one out as it was ok last year..
neckarsulm
RE: Re: RE: Nearly failed MOT on emissions?!?!
Post by neckarsulm » Sat Oct 09, 2010 8:10 pm
Standard or Milltek? I'd say possibly post cat air leak in exhaust but could be other things
Do you have Co2 and O2 readings as well?
scaghead
Post by scaghead » Sat Oct 09, 2010 8:23 pm
standard exhaust system fella.. would it be a case of i dont really use it that often and it needs me to give it a bit of a tanking to clear it out a little :D the op had the same issue but it self cured while he was there :? ...i will take it back monday and give it another go... if not a trip to the good old dealers for me..
the only readings i have are those above fella...
neckarsulm
Post by neckarsulm » Sat Oct 09, 2010 9:53 pm
It's quite normal for a car to take a couple of goes to get through the emissions test especially if it's been around town a lot.
I'd appreciate Minhea's (S2tuner) view on this but I always thought cold cats (but engine fully up to operating temp) would increase the CO as well as mess up the lambda.
Dom81
Post by Dom81 » Sun Oct 10, 2010 12:29 am
neckarsulm wrote:It's quite normal for a car to take a couple of goes to get through the emissions test especially if it's been around town a lot.
Interesting. I worried reading these posts, so dug out my latest (and so far, only) emission results from an MOT test in March. At fast idle they were -
CO 0.01% (limit =< 0.20%)
HC 8ppm (limit =< 200ppm)
Lamda 1.002 (tolerance 0.97 - 1.03)
No comfort to Scaghead or the OP, but since the car is low mileage and crucially does nothing around town, I guess it might be that the stop / start and cold runs contribute?
2007 Daytona RS4 Avant
scaghead
Post by scaghead » Sun Oct 10, 2010 3:59 am
you could be right there fella. i will see what happens on monday 8)
sonny
Post by sonny » Sun Oct 10, 2010 8:22 am
Was it a dealer or Indy you had the MOT done?
Users browsing this forum: Majestic-12 [Bot] and 150 guests
