Are these two issues inter-linked?
rtd
Post by rtd » Sun Jul 19, 2009 10:36 pm
Did Vagcom this morning which threw up the following fault code;
1 Fault Found:
16622 - Manifold Pressure / Boost Sensor (G31): Signal too High
P0238 - 35-10 - - - Intermittent
Readiness: 0000 0000
then ran the 032 feature and got the following readings;
Group 032: Lambda Control (Mixture Adaptation)
1.9 % Adaptation (Idle) Bank 1 Sensor 1
-17.2 % Adaptation (Partial) Bank 1 Sensor 1
2.1 % Adaptation (Idle) Bank 2 Sensor 1
-16.4 % Adaptation (Partial) Bank 2 Sensor 1
can't believe that i may have another boost leak having had one fixed by doug a week a go. could it be that i am getting the above fault code as a result of the suspected boost leak?
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
Virdee Autos
Trader (Expired)
RE: Are these two issues inter-linked?
Post by Virdee Autos » Sun Jul 19, 2009 11:02 pm
I would clear the DTC, and then see if it re-appears as it says intermittent
Although yeh does seem you have a boost leak.
Virdee Autos ~ 07950-526592
rtd
Re: RE: Are these two issues inter-linked?
Post by rtd » Mon Jul 20, 2009 9:42 am
Virdee Autos wrote:I would clear the DTC, and then see if it re-appears as it says intermittent
thanks virdee - i cleared and it came up again....
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
Return to “DTC / VCDS”
