Very occassionally, my 2001 S3 doors are shut, but the dash shows it open (interior light stays on too). Any ideas of what to check?
Door open sensor?
Door open sensor?
APR 270bhp S3, Mixer K6 750
philipwalker
- 5th Gear
RE: Door open sensor?
There is a switch in the door lock.
These play up only real fix is to replace the door lock unit iro £60 last time I did one...
Re: RE: Door open sensor?
Cheers Phil. I'll be leaving that thenphilipwalker wrote:There is a switch in the door lock.
Will spraying WD40 into the lock help?
- PetrolDave
Or remove the door lock yourself and adjust/replace the microswitch which either costs nothing (if you can adjust it) or a few quid if you replace the switch.philipwalker wrote:There is a switch in the door lock.
