032 measuring block
rtd
032 measuring block
Post by rtd » Mon Jun 29, 2009 5:56 pm
does this look right?
Group 032: Lambda Control (Mixture Adaptation)
1.9 % Adaptation (Idle) Bank 1 Sensor 1
-17.2 % Adaptation (Partial) Bank 1 Sensor 1
2.4 % Adaptation (Idle) Bank 2 Sensor 1
-17.2 % Adaptation (Partial) Bank 2 Sensor 1
they have changed from the last time i checked......the 2nd banks are far higher anything to worry about here?
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
JonnyX
RE: 032 measuring block
Post by JonnyX » Mon Jun 29, 2009 6:26 pm
No, you are running mega rich on multiplicative trim. You don't mention what car you have but I guess it's
a turbo with a boost leak.
MY 2000 S4
Ebony Pearl
Stage 3 (MRC 400 (ish))
Apexcone 50w HIDS
rtd
Post by rtd » Mon Jun 29, 2009 6:27 pm
hi car is in sig! B5 RS4
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
JonnyX
Post by JonnyX » Tue Jun 30, 2009 10:09 am
Doh!
I'm pretty sure you have a boost leak. The positive numbers on additive trim mean you are a little lean
on idle - sucking in unmetered air through your boost leak. Get it to someone who can pressure test the
intake for you (MRC).
MY 2000 S4
Ebony Pearl
Apexcone 50w HIDS
rtd
Post by rtd » Tue Jun 30, 2009 10:10 am
thanks mate will get it seen too.....
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
rtd
Re: RE: 032 measuring block
Post by rtd » Mon Jul 13, 2009 9:16 am
JonnyX wrote:Doh!
you were right mate had a big boost leak but all sorted now, thanks again.
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
Return to “DTC / VCDS”
