Gearbox and Differential oil change?
Are they included in any of the services, I notice that there is no inventory in the service book for them, but surly they will need to have the oil changed at some point. Has any body changed there's?
This debate has been going on for some time within the BMW CC USA. The concensus seems to be that when manufacturers guarantee the units for life we should be happy with "lifetime fill". Until then, changing the gearbox & final drive/s fluids at around 50k/60k can do no harm and it's probably a wise precaution. That's assuming, of course, that they're able to be drained & refilled. BM's are. Don't know about Audi's................ Anybody looked?
There might be a level bung on the side of the gearbox that you could fill it through but i really would get some tech help to check first,overfilling could damage the gearbox,iremember one of my escort cossies had a slight leak and had a level bung on the side of it,But the correct level was 10mm (or something) below this and ford used an allen key as a dipper,a friendly tech might be able to help
I have done this now and it was very easy after all. There is a filling bung (10mm allen) on the side of the front diff/gearbox which is just next to the nearside driveshaft flange. The gearbox holds 3.5 ltrs as suggested by TPS who supplied the gear oil. The filling is quite simple, I got a piece of hose and ran it down behind the engine and into the filling hole. Then you just feed the oil in through the hose checking every so often. Coincidently 3.5 ltrs is up to the level of the filling hole on the gearbox. I hope this helps anyone who would like to know as I did.
Details from ElsaWin:
GEARBOX
The vehicle must be horizontal when checking gear oil level.
– To check gear oil level, unscrew oil filler plug
Check oil level with a suitable tool (such as a length of wire bent to shape).
Oil level for gearbox with code letters GYH
l Specification: Oil level is correct when gearbox oil is up to lower edge of filler hole.
Oil level for all other gearbox versions
l Specification: Oil level 2 ± 1 mm below lower edge of oil filler hole.
40Nm torque for filler plug
RS4 box is HND i believe, so we are the 2mm below edge.
GEARBOX
Users browsing this forum: No registered users and 332 guests
