Pressure tested, got leaking injector seals....
2.7 V6 30v biturbo - 380 bhp
neckarsulm
Post by neckarsulm » Sat May 30, 2009 7:04 pm
Finally got my pressure tester off Ebay and it seems to work fine.
Noticed some leak from top of inlet manifold and after pouring some water it was obvious that the injector seals on cylinders 2 and 5 were leaking.
Anyone know how easy they are to replace and also if this would have much of an impact on performance?
gezzerS4
Post by gezzerS4 » Sat May 30, 2009 7:20 pm
Hi Neckarsulm,
sorry cant help with your question but I have just ordered one of those from ebay, what did you use to put air into the system, the blurp on ebay states a tyre inflator not a footpump ??
cheers
RS4 Avus Silver, HiTech Interior, Stage 3, Milltek & Cats, H&R, Sportec ARB's, Forge DV's
neckarsulm
Post by neckarsulm » Sat May 30, 2009 7:32 pm
I bought a 2.5hp air compressor from Aldi for £80 a few weeks ago and it works a treat.
Works on normal 240v and does the job.
Can also be used for inflating tyres and as a pressure washer and also useful for just blowing out the crap from spark plug recesses before replacing plugs.
You do need at least one of these for the pressure tester to work properly, a foot pump or even a 12v portable compressor wont work.
drjones1
Post by drjones1 » Sat Jun 06, 2009 7:50 pm
I did mine today. Had a massive leak from the top of one of the intercoolers went to take it apart to clean and refit and the jubilee clip wasn't even done up!! the hose was only push fit i guess it couldn't blow off as it is sandwiched between the two points.
Certainly feels more responsive.. shows i dont drive it that hard as i hadn't noticed..
So much for the benefits of a FASH... w@@kers..
A8 3.0TDI quattro sport (every day)
B5 RS4 (the second one)
UR quattro (450bhp)
AC Cobra (replica)
Ford GT40 (replica)
A3 (Wife)
Sit on lawn mower (12hp....)
Users browsing this forum: No registered users and 110 guests
