Can't change coding on 46 Central Conv
Post by Shoppinit » Mon May 25, 2009 6:56 pm
Sorry if I'm being dim, but I can't seem to change the coding on a friend's 2005 A4 so that the horn beeps when he locks the car with the remote.
I've tried adding 1024 (and removing it) and tried other codings. When I click "do it", the coding just goes back to 07024. I've tried various combinations.
Do I need to login first or something?
(using genuine ross-tech and version 8xx)
RE: Can
Post by Shoppinit » Fri Jun 05, 2009 12:09 pm
Anyone?
Sebastian
RE: Can
Post by Sebastian » Mon Jun 15, 2009 10:50 am
Lets start with some more information on the car itself, please post a complete Auto-Scan from the vehicle in question. This will allow us (even without fault codes) to take a closer look which components are installed and which control modules you have there (i.e. part numbers and such).
Sebastian @ Ross-Tech.com
Post by Shoppinit » Mon Jun 15, 2009 11:03 am
Hi Sebastian,
Thanks for replying. Here is the full scan:
VCDS Version: Release 805.3
Data version: 20090213
Saturday,23,May,2009,20:51:31:19387
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN: WAUZZZ8EX5A Mileage: 82360km/51176miles
Address 01: Engine Labels: 03G-906-016-BLB.lbl
Part No SW: 03G 906 016 GN HW: 028 101 211 3
Component: R4 2,0L EDC G000SG 9618
Revision: 12345678 Serial number:
Coding: 0000072
Shop #: WSC 05220 995 88289
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 8E0-910-517.lbl
Part No SW: 8E0 910 517 B HW: 8E0 614 517 AT
Component: ESP8 front H04 0180
Revision: 00000000 Serial number: 00000000000000
Coding: 0004401
Shop #: WSC 06325 000 00000
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AM
Component: A4 Klimaautomat 2831
Coding: 00000
Shop #: WSC 00000
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 L
Component: int. Lastmodul ECE 0504
Coding: 11001
Shop #: WSC 65536
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 G HW: 8E0 959 655 G
Component: Airbag 9.41 H11 3530
Revision: 91H1135 Serial number: 0036M004CC1H
Coding: 0033622
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 Q
Component: Lenksáulenmodul 0601
Coding: 02042
Shop #: WSC 06325
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 900 R HW: 8E0 920 900 R
Component: KOMBI+WFS 4 H12 0040
Revision: 0040 Serial number: 00000000000000
Coding: 0006141
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 BR
Component: Komfortgerát T23 3332
Coding: 07024
Shop #: WSC 06325
Part No: 8E1959801F
Component: Tõrsteuer.FS BRM 1315
Part No: 8E1959802E
Component: Tõrsteuer.BF BRM 0205
Part No: 8E0959801A
Component: Tõrsteuer.HL BRM 0205
Part No: 8E0959802A
Component: Tõrsteuer.HR BRM 0205
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8E0 035 195 M
Component: symphony II PM6 0410
Coding: 01005
Shop #: WSC 06400
Address 76: Park Assist Labels: 8E0-919-283-8EC.lbl
Part No SW: 8E0 919 283 B HW: 8E0 919 283 B
Component: Parkhilfe 4-Kan H06 0020
Revision: 00H06000 Serial number: 00067802030510
Coding: 0000014
1 Fault Found:
01548 - Sensor for Parking Aid; Rear Right (G206)
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 3
Fault Frequency: 15
Reset counter: 36
Mileage: 0 km
Time Indication: 0
Date: 2000.01.01
Time: 00:00:00
End ---------------------------------------------------------------------
Post by Shoppinit » Thu Jun 18, 2009 10:27 pm
Any ideas then? Maybe the ignition needs to be off?
Sebastian
Post by Sebastian » Fri Jun 26, 2009 10:55 am
According to the original coding your car has no anti-theft system to begin with, therefor you cannot enable the confirmation tone.
Post by Shoppinit » Fri Jun 26, 2009 11:03 am
That makes sense. Thanks. Doens't explain why the coding wouldn't change, though.
Unless it was to stop me programming a stupid value in? But I thought they would let you make mistakes like that.
Sebastian
Post by Sebastian » Fri Jun 26, 2009 3:26 pm
Some codings are checked for plausibility and then rejected because they are "senseless". ;) In your case, having the bit for the confirmation ticked without an actual anti-theft system being installed is a proper reason for a rejection.
Post by Shoppinit » Fri Jun 26, 2009 4:35 pm
That makes sense. Although I did try adding / subtracting 1 (LHD / RHD) to see if it woudl take the coding, but it didn't in either case. Never mind. Not my car :)
Post by Shoppinit » Sat Aug 15, 2009 11:16 am
Never could change the coding on this module. No idea why.
Return to “DTC / VCDS”
Users browsing this forum: Google [Bot] and 53 guests
