Some help required here.
'98 S4 saloon
It wasn't working when I bought it. I'd like to take a look, so some diagnostic pointers would be useful. Is there anything that is a common problem? Where are all the bits hiding?
When it is functioning, what indications are present?
cruise control
MarkHanman
RE: cruise control
Sorry no visual or audible indications for cruise.
2001 Silver S4 Avant
MarkHanman
RE: cruise control
sort of a bump...
Checked both pedal switches, and these are fine.
Is there anyone on here with some technical pointers?
Is this something that Vagcom can help diagnose (excuse dumb question, I normally play with older kit)
RE: cruise control
Okkim is the daddy for his awesome guide!
Yeah you can look at the function of the cruise control switch on vagcom, Measuring blocks. This might help
http://www.valitalo.org/cruise_control_installation.htm
You can check the functioning from measuring block 66
Regards
Stigter
Regards
Stigter
MarkHanman
Maybe post where you are located and someone might be able to assist with Vagcom.MarkHanman wrote:cool
Thanks for that.
And a VAGCOM unit will be next on my equipment list.
Audisrs.com is another forum like RS246.COM - most of the people on here are also on there! They made a map showing where people who had vagcom where: http://platial.com/mapv/AudiSRS+VCDS+volunteers/520173#
Might help
