Prefered Engine Oil
MICALEE
Prefered Engine Oil
Post by MICALEE » Sat May 02, 2009 8:46 pm
Looking at the handbook, it states VW 501 01 engine oil. What do you use which is easily found at Helfrauds, Homebase, garages etc?
Ridgeway
Post by Ridgeway » Sat May 02, 2009 11:21 pm
Also interested to heare peoples views on this
Pete.S
Post by Pete.S » Sun May 03, 2009 2:49 am
cobraBLACK
Post by cobraBLACK » Sat Dec 04, 2010 11:55 am
I used to use Castrol Edge 5w 30 but am off the variable service and now use Fuchs Titan Race Pro S 5W-40 Ester Synthetic Engine Oil, as recommended by Opie Oils.
It'll also help if you have the tensioner rattle on startup.
Audi S4 Avant (B6, 2004) in Goodwood Green.
geecom
Post by geecom » Wed Dec 08, 2010 12:26 am
For the first time since I've had it (45k, 3 yrs) I've needed to top up my car with oil - no idea why as my driving hasnt changed.
Anyway, I looked into the oil it uses: the local Audi garage uses Castrol SLX 5W-30 (about £21 for a litre bottle), which in Halfords retails as Castrol Edge (about £17 for a litre bottle).
Does it make much difference? My car rattles like crazy, despite having had a new chain and tensioners and differnt types of oil tried at about 60k. I always cringe whenever I hear it.
cobraBLACK
Post by cobraBLACK » Wed Dec 08, 2010 12:33 am
geecom wrote:Does it make much difference? My car rattles like crazy, despite having had a new chain and tensioners and differnt types of oil tried at about 60k. I always cringe whenever I hear it.
It does, straight away.
It's not fully eradicated but it's quieter and shorter and sometimes it doesn't do it at all.
The fella at Opie Oils said it was the ester content which helped. He said I could go for 5w 30 or 5w 40 so I went for the latter (thicker) to be sure.
Mine's done more then twice your mileage. You might wanna get a bespoke recommendation from them but I'd have thought they'd suggest the same.
cobraBLACK
Post by cobraBLACK » Wed Dec 29, 2010 1:34 pm
UPDATE: Over the last couple of weeks I'd say there's actually no rattle more often than there's any rattle - and if it does rattle it's short and quiet.
xyber
Post by xyber » Wed Dec 29, 2010 5:44 pm
Yep, even when I started mine the other morning when it was -11.5oc there was only the slightest noise. You couldn't call it rattle, more of one very short click.
geecom
Post by geecom » Sat Feb 05, 2011 12:25 pm
biyitch wrote: The fella at Opie Oils said it was the ester content which helped. He said I could go for 5w 30 or 5w 40 so I went for the latter (thicker) to be sure.
Thanks. Mines actually on about 90k - I got it with 35k on the clock - but will drop them a line and see what they say.
If you use a different oil manufacturer, can you just top up, or would you recommend flushing it through and changing it completely. I'm on variable too, and probably need a service in about 4k.
aligod78
Post by aligod78 » Sat Feb 05, 2011 12:43 pm
Still feeding mine Castrol Edge 5-30. 4L every 3 months or so. Opie Oils sometimes do free postage, so works out cheaper than Halfrauds ;)
Still get chain tensioner rattle, but I'm up to 147k now, not surprised. Not worries tough, lasts a second. Any more and I'd be worried.
cobraBLACK
Post by cobraBLACK » Sun Feb 06, 2011 12:41 am
geecom wrote:If you use a different oil manufacturer, can you just top up, or would you recommend flushing it through and changing it completely. I'm on variable too, and probably need a service in about 4k.
See here:
http://www.rs246.com/index.php?name=PNp ... ic&t=83633
