AUDI RS6 DRC PROBLEM. WHAT SUSPENSION DO YOU RECOMMEND
RS6AVANTWALES
Hi I'm a new user here and have bought an RS6 with the dreaded DRC problem. I am not going to put the audi system back on, and want to know what is the best make to put on the audi for road use. would anyone know any good supliers. what has this cost you?
Any help would be great.
Thanks Paul
Thanks Paul
RE: AUDI RS6 DRC PROBLEM. WHAT SUSPENSION DO YOU RECOMMEND
If you do a quick search, you'll find a lot of discussion. Bilstein, H&R, KWv3 seem to be the choices, there are even stickies related to them.
I have KW v3, and they are highly adjustable, but this makes set up tricky.
As you're (possibly) in Wales, Unit20 who are round Ellesmere Port can talk you through the options.
- RS6 Mugello
- 2nd Gear
I have Bilsteins PSS9 which have 9 settings and therefore easier to setup . Unit 20 and Grizz highly recommended and probably closest. I used MRC in Banbury whom are excellent. good luck
James
James
Mugello blue saloon with MRC re-map 1+, Bilstein PSS9, Hotchkis ARBs and resonated Milltek cat-back, Kenwood DAB/Sat Nav/Ipod/Bluetooth
get yourself to grizz , H&R's with Hotchkiss ARB's , bloody marvellous , though a little hard on bad road surfaces . More than makes up for it in the bends
Phil
Phil
I have the H&R coiloivers with the Arb's awsome!!
RS6 Avant, black with black wheels, front S6 led lights, rear smoked Led lights, miltek non-res, miltek cat by-pass down pipes, ITG air filters, H&R kit with Arb's, MRC stage 2
I have Bilstein PSS9 and very pleased. Worth getting adjustable to suit your needs and road type but I opted for Bilstein as they have 9 settings rather than infinite (like KW). Hard to compare brands as you only fit them once!
RS6AVANTWALES
thanks for the help can fit the suspension myself but may need it set up by someone what sort of money difference are there between these kits? who's the best company to buy from.
thanks again for your help.
grizz , grizz , grizz , say no more , he generally keeps the h&r's in stock
H&R'Sin stock , special offer on saloon kits ...
Unit 20
0151 3366888
0151 3366888
moleinthehole
I believe Demon Tweeks keep both the KW's and Bilstein's on the shelf.
Demon Tweeks don't keep any thing on the shelf....... They get it sent from the importer direct to you.
Unit 20
0151 3366888
0151 3366888
RS6AVANTWALES
Thanks for all your help choose bilstein pss9's after from europerformance
moleinthehole
When I phoned, they offered me next day delivery or the option to collect from the Wrexham shop that day. I spoke to Paul (01978 663025), who told me that due to demand, they now stock both kits on the shelf.
We have another Pss9 kit in stock for the RS6. The damping is superb for road use.
You get what you pay for with suspension kits. Ohlins anyone?
Users browsing this forum: philS2 and 129 guests
