Hi, anyone know what this is ?
Address 01: Engine
Control Module Part Number: 8E1 910 560
Component and/or Version: 4.2L V8/4V FSI ª0090
Software Coding: 010C0003180F0160
Work Shop Code: WSC 00460
1 Fault Found:
006435 - Please Check DTC Memory of ECU Number 2
P1923 - 008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 1
Mileage: 55380 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 79.0°C
Temperature: 63.0°C
Absolute Pres.: 990.0 mbar
Voltage: 12.192 V
Readiness: 0000 0000
Vagcom fault code P1923 B7 RS4
07/07 RS4 Avant Mugello Blue
- Virdee Autos
- Trader (Expired)
RE: Vagcom fault code P1923 B7 RS4
Need to access ECU no.2, which I think is address code 11 IIRC.
Or lookout for Engine II or something like that
Virdee Autos ~ 07950-526592
- PetrolDave
The B7 RS4 has two engine ECUs (at addresses 1 & 11), seems that engine ECU 2 has a fault code stored.
Each ECU controls 1 bank of the engine.
