Engine mount fault
ecain63
Engine mount fault
Post by ecain63 » Sat Apr 25, 2009 4:50 pm
Chassis Type: 4B - Audi A6 C5
Scan: 01 02 03 06 08 15 16 17 18 34 35 36 37 45 55 56 57 65 67 75
76 77
VIN: WUAZZZ4BX3N902582
Address 01: Engine Labels: 077-907-558-BCY.lbl
Part No: 4D1 907 558
Component: 4.2l V8/5VT G 0003
Coding: 0010752
Shop #: WSC 66565 257 00032
1 Fault Found
17983 - Right Engine Mount Solenoid Valve (N145): Short to Plus
P1575 - 001 - Upper Limit Exceeded
Readiness: 0000 1000
Is this serious. Makes no diference to the driving experience.
Now Sold!
'03 Daytona Grey RS6 Avant.
275 Vreds.
MRC custom map with TCU.
Miltek Resonated.
Hi Flow filters.
19" 'Plus' (Grey) rims.
vinny
RE: Engine mount fault
Post by vinny » Sun May 10, 2009 3:00 pm
and here again, eddie... the engine mounts have electrical pressure sensors built in to register engine torque - if the ecu picks up a fault, it should back off the power slightly to avoid damage - had a car in the other day. two options - the factory have a wiring mod for the A8's which im sure will work here (and you can put whatever mountings you like in) or replace the mounting with the factory part....
ecain63
Post by ecain63 » Sun May 10, 2009 6:25 pm
Much appreciated mate. I'll have a browse.
Now Sold!
275 Vreds.
Miltek Resonated.
Hi Flow filters.
ecain63
Post by ecain63 » Fri May 15, 2009 6:32 pm
New OSF engine mount fitted. Fault code has gone. No more fault codes remain after driving. Problem solved at a cost of £250. £106.56 for the part + VAT then the labour.
Now Sold!
275 Vreds.
Miltek Resonated.
Hi Flow filters.
Return to “DTC / VCDS”
