Running too rich?
TopBear
Running too rich?
Post by TopBear » Wed Apr 22, 2009 4:56 pm
Looking at the 2nd figures them seem to be higher than I remember before, though the 'idle' figures are down from ~8% since I got the SAI vacuum pipes sorted
Address 01: Engine (8D0 907 551 K)
Group 032: Lambda Control (Mixture Adaptation)
2.1 % Adaptation (Idle) Bank 1 Sensor 1
-16.4 % Adaptation (Partial) Bank 1 Sensor 1
0.8 % Adaptation (Idle) Bank 2 Sensor 1
-17.2 % Adaptation (Partial) Bank 2 Sensor 1
No DTC's logged in the engine module.
If already looked here http://wiki.ross-tech.com/index.php/Fuel_Trim_Info
and here http://forums.vwvortex.com/zerothread?id=1265064 , but none cover high -ve values. :?
:blackrs4: B5 RS4, MRC Remap, Milltek, RS6\B7 Brakes, Black\Carbon
almeister09
RE: Running too rich?
Post by almeister09 » Thu Apr 23, 2009 5:22 pm
you have an air leak . check and change the vac valve under the air filter housing. Can be seen if you remove the wing liner on O/S/F
Return to “DTC / VCDS”
