All
Looking for ideas please - changed both rocker cover gaskets a few weeks ago which as you know means removing intake pipe etc etc.
Car has now devleoped a strange whinig noise on the over run - when revved hard (once warm) onj release of the throttle the noise occurs - sounds like a either an air intake leak ? or ...gulp... a turbo bearing??
Your wisdom would be appreciated!
Brent
Odd Noise - Im Baffled
- leyshonbrent
Misano Red B5 RS4 - For Best
Battered A4 1.9 TDI Avant - my weekend van and Station Wagon
Mk1 Escort Mexico - Childhood Sweetheart
For Family - VW Touran 2.0 TDi Sport
RE: Odd Noise - Im Baffled
Is it in every gear?
I mean if it was only say third then it could be gearbox problem (early RS4's are notorious for failing boxes).
If it's in every gear or in say 5th and 6th for more of a prolonged period from lower revs then it could point to turbo's are they are under boost for longer periods.
Have you tried running VAG-com to check if it's a boost leak or not?
2001 Avus Silver RS4 B5 60k on clock, MRC Custom Remap, Sunroof, Bluetooth prep
2006 Daytona Grey RS4 B7, RNS-E - SOLD
2006 BMW M6 - GONE
2006 BMW M6 - GONE
- leyshonbrent
Thanks for the response
It occurs when the car is stationary or when on road - had bonnet up last night and appeared to be coming from front of engine - also is not constant - only happens on revving and is worse on overun - then is undetectable at low rev range.
I have vag com so I will run it tonight. There does not seem to be any affect on performance although I have used the car very little since this problem came up.
