B6 alloys on B5
B6 alloys on B5
Do you guys know if the standard B6 S4 alloys fit the B5 S4?..
Rotta..
Rotta..
RE: B6 alloys on B5
Yes they do.
Look great too, you may or not need spacers, I needed spacers with 235's but didn't need them with 225's.
RE: B6 alloys on B5
Yes, got a set on mine. If they're definately ET35 they'll fit straight on..
RE: B6 alloys on B5
I think the ET35 are the replica ones, IIRC mine are ET43? (As mikey states below the OEM ones are ET45)
RE: B6 alloys on B5
Sorry.. my mistake. I meant ET45...
Blue_Thunder
- Top Gear
RE: B6 alloys on B5
Here's mine:
I've got 5mm spacers up front and 10mm spacers at the back to fit over my RS6+ brakes.
Re: RE: B6 alloys on B5
What ET? ET45 + 5mm spacer isn't that wide, or? :)Blue_Thunder wrote: I've got 5mm spacers up front and 10mm spacers at the back to fit over my RS6+ brakes.
Looks great, BTW!
Blue_Thunder
- Top Gear
My front brakes have large belsl, hence the wider spacers at the rear to maintain a similar track.raboc wrote: What ET? ET45 + 5mm spacer isn't that wide, or?
Looks great, BTW!
Welcome to the site.
- tdiquattro
RE: Re: RE: B6 alloys on B5
Clearance issues are
brakes at the front
and the suspension upright on the inside of the rim at the rear,
that's what the spacers are for so it depends on the tyres/front brakes.
brakes at the front
Nige'
2000 silver S4 Saloon
What about S8 Avus-es? (18x8)
I believe spacers are needed?
I ran 235s on mine without spacers although as mentioned above clearance on the rear suspension upright was tight. I may have posted a pic of this a while back......can't rememberreserves
Yes they do.
Not all tyre manufacturers 235s will be exactly the same width so some may fit better than others. The wheels I had came with Dunlop SP Sport 01 tyres.
- Kaapse_Laaitie
- 1st Gear
Blue_Thunder
- Top Gear
